Hearing knock w/ 2.85 pulley and 60# injectors
Initially I thought I heard an exhaust rattle, but it is only under load about 2.5k-4k rpms. Dealer said it was definitely fuel ping. Car has 2.85 pulley 60# injectors (professionally dyno tuned) and has good air:fuel through the rpm range and didn't see knock on the dyno. I'm looking for some suggestions because I need it to stay reliable, plus I hate hearing it in second gear when I go wot. Hopefully its just a tank of shitty gas but I always use 93 octane. I'm ordering a heat exchanger right away to lower temps, that might help. I'm looking for some other good suggestions.
I don't have the dyno sheet here but I believe the air fuel was right around or slightly below 12:1 at WOT at 7000rpm. I'll ask my tuner to look it up in the computer. As far as heat goes, I'm ordering the CX racing h/e this week.
How is the AFR through the RPM range, especially at 2.5 - 4K when you hear the pinging? 12:1 is high, 11.5:1 would be more desirable to protect against detonation especially if you don't have cooling mods. With 60# injectors you should be running low IDC so bumping up the AFR should be easy. If you arne't seeing knock on a meter, then you may not be getting actually pinging it might just be the injectors being noisey. I would definately check the AFR through the entire range though.
I'm waiting for my tuner to refres my memory on exactly what the AFR is through the range but it was a smooth line with no major fluctuations, definitely not running dangerously lean. It's not the injectors being noisy because the sound is almost like when a catalytic converter cover is about to fall off an older car and you can hear it vibrating. Its a metallic rattle type sound, not an exhaust problem either. It has a catback and cold air intake so that is at least a marginal help for IAT2s.
Correction: Confirmed that AFRs are in mid to high 11s through entire RPM range. Area, I'll have to check on the timing advance for this tune next.
Well I dumped a bottle of octane booster into a little more than 1/4 tank of gas left in the tank and did a test run. It only raises the octane rating one point but should be more concentrated in 1/4 tank. The sound is much less audible than before and is most noticeable at around 3800 rpm and can be heard faintly from 3000. But I don't know what exactly I proved, the culprit could still be bad gas but I won't know until I finish the tank and refill, and until then I'll be annoyed as hell.
Area47, it doesn't have any effect whether I stab the gas or let into it gradually when I go full throttle. Looks like I should get myself a wideband to see whats up.
Last edited by PocketRocket06; 06-03-2008 at 05:53 PM. Reason: Automerged Doublepost
definitely get a wideband. I think you are a little too lean though. You should be about 11.5 or even a tad richer when off the meth, and you need to check your timing. The heat is killing you though for sure.
I almost never beat on it and the last time it was brought to redline was on the dyno so I don't abuse her, in fact the reason I am so concerned about this is reliability. And not driving it hard doesn't solve the problems that still exist at wot. I just think it is strange that it happened so suddenly. I'll see what happens after I get the heat exchanger on and a fresh tank of gas. Thanks for all the input.
Holy posting in like 5 minutes! Jeeze guys lol. I'm sticking with the 2.85 for the summer.
And I'm telling you that a 2.8 pulley with no cooling mods, isn't going to be a HUGE difference from a 2.9 pulley car with no cooling mods. How hard is that to understand? It's only .1 difference.
I'm pretty sure there isn't.
