Heat exchanger creating a vaccum?
Old May 19, 2020 | 12:34 PM
Tom10122's Avatar
I recently added the zzp heat exchanger inline with my stock one and am having trouble bleeding it.
With the pump on, it sucks down all the coolant in the resivour neck.
When it is off, if I open the cap, it shoots out(warm or cold)
Wtf, I've had to completely fill the stock one before and didn't have this issue, what should I be looking at here?
Old May 19, 2020 | 12:49 PM
How did you route the lines?
Did you bleed the stock heat exchanger?
Old May 19, 2020 | 12:51 PM
Tom10122's Avatar
I went from the resivour, to the new h/e, to the original one.
Stock was bled before installation
Old May 19, 2020 | 01:14 PM
Which reservoir are you talking about?
Old May 19, 2020 | 01:15 PM
GM's routing recommendations
Originally Posted by csementuh
The GM Dual Pass instructions say run it this way... I don't understand why people thing the pump cant handle the temperature...
Old May 19, 2020 | 01:17 PM
Tom10122's Avatar
The filler neck with a tiny resivour, I have it routed this way only with the stocker and aftermarket exchangers switched
Old May 19, 2020 | 01:22 PM
I'd check for plugged/kinked lines
Old May 19, 2020 | 02:50 PM
steelmesh's Avatar
That coolant has to go somewhere, the path of least resistance should be back to the filler neck from the other end. You're probably not the first person to do this mod so it could be unique to your situation, so you might have to bypass each intercooler to see if there is a restriction as an idea to start if you don't see any kinks/pinches.
Old May 19, 2020 | 06:04 PM
Tom10122's Avatar
Just checked for kinks, nothing obvious. Going to need to drop it and take a look this weekend.
Old May 20, 2020 | 02:29 AM
bubba_jay's Avatar
How can you bleed the stock one before the installation? I'm thinking its air in the system somewhere.
Old May 20, 2020 | 07:26 AM
Tom10122's Avatar
Since I went from the neck, I just pulled the hose that goes from it to the stock h/e, leaving all the coolant in the exchanger
Old May 20, 2020 | 08:29 AM
jdbaugh1's Avatar
I have to agree with bubba. There almost has to be air trapped in the system. The water isn't compressing so the coolant level dropping is probably from the pump compressing the trapped air bubble. I've found the stock pump to be weak enough that purging the air out of the system can be a pain in the ass.
Did you try adding coolant as the pump sucks it down from the reservoir until the reservoir stays full with the pump on? You could do this and then install the cap before turning it off and may help purge the air. Also make sure the pump is primed. If it get's an air bubble stuck at the inlet it can have trouble self priming.
Old May 20, 2020 | 08:33 AM
Since there are no kinks, I'd lean towards an air locked system. Open the bleeder on top of the stock heat exchanger and keep adding coolant to the tee as it goes down.
YelCal7
Sep 10, 2012 11:51 AM
SSJohn
May 5, 2010 08:49 AM
06_black_cobalt_SS
Jul 29, 2008 05:38 PM
Tennpenn83
Jul 7, 2008 12:26 AM
cobaltz51r
May 21, 2008 08:35 PM
