heat exchangers
Go to search on top, and type in heat exchangers, and then select "Search post titles only". Dont forget to click the "2.0 Performance Section" so you get accurate results.
Alot will come up, you can get tons of information from that stuff that pops up.
No way to fit it all. On top of that it gets to a point to where your cooling will be inefficient because the proper amount of air is not getting to each heat exchanger. Just do what I did and run the OTTPerformance Heat Exchanger with the stock unit. My IAT2's went from 127* from bottom of 2nd to top of 3rd down to 113* in roughly the same ambient temps.
I've got pics if you want to see them.
n20saturn
09-30-2015 12:26 AM
