Help
Old Apr 19, 2008 | 05:37 PM
chad463's Avatar
Help
I just installed my Vibrant header/dp and my 2.9 inch pulley and it seems my car has lost power. What could be the problem? I dont have any CEL's or anything it just seems like the car is sluggish.
Old Apr 19, 2008 | 05:38 PM
boostedss26's Avatar
what are you runnin for boost?
Old Apr 19, 2008 | 05:40 PM
chad463's Avatar
105kpa around there
Old Apr 19, 2008 | 05:42 PM
GreenPurgatory's Avatar
I have read that it seems like you loose power, but in fact you haven't. I think it was an0molous that said, it felt less powerful, but did the 1/4 mile faster.
The only sure way of knowing is taking it a dyno.
If there is a problem, it might be an exhaust leak or something.
Last edited by GreenPurgatory; Apr 19, 2008 at 05:42 PM. Reason: Automerged Doublepost
Old Apr 19, 2008 | 05:57 PM
ItalianJoe1's Avatar
Def should not feel less powerful with a smaller pulley and exhaust... You sure the belt is not slipping on the pulley? Stage 2 belt, right?
Old Apr 19, 2008 | 05:59 PM
Sunburst_SS's Avatar
well, I assume you put bigger injectors and a tune to go along with the pulley right?
Old Apr 19, 2008 | 06:05 PM
I am going to have to say, that in reading over it again, I did not realize that the pulley was changed. That could be the source of your problems, the other stuff should not affect much as I said before.
Old Apr 19, 2008 | 06:57 PM
chevysssc's Avatar
u may loose tq with the header and dp but gain top end hp
tune it
Old Apr 19, 2008 | 08:13 PM
chad463's Avatar
I seen that people ran the 2.9 with the stage 2 tune fine. I was wondering if there was a leak somewhere in the exhaust would this cause a noticeable power loss. Yes I do have the stage 2 belt.
Old Apr 24, 2008 | 02:24 PM
QuikSilverSS's Avatar
what are you running for a catback????
Old Apr 24, 2008 | 03:02 PM
chad463's Avatar
Gmpp
Old Apr 24, 2008 | 03:08 PM
RuSSo-29's Avatar
I have the Vibrant H/Dp and Down low it felt a lil softer, or less powerfull. But It should feel stronger mid range and up... then again if your loosing power there is bigger problem
Old Apr 24, 2008 | 03:41 PM
chad463's Avatar
I had a leak, I got it looked at and got it fixed.
