Help !!!!!!!!!!!!
Old May 10, 2008 | 10:32 PM
CentralBlvd08's Avatar
Help !!!!!!!!!!!!
Okay drove home car was fine parked it washed the car after filled up my meth tank about half way 3 hrs later go to get in my car it doesnt start and jutters when start, when it turns on boost gauge is goign crazy and my car is sputtering and WHITE smoke is coming out shut of the car and i can still hear my meth pump check the tank and all the meth i put in it is gone!!! WHATS WRONG!!
Old May 10, 2008 | 10:34 PM
D4u2s0t's Avatar
well, i would assume you have a leak?
Old May 10, 2008 | 10:36 PM
checked the lines and nothing like i said car was 100 mint when i came home i know i didnt blow a number 4 because i wasnt driving lol
Only thing i can guess is myabe i filled it to much i dont know
Last edited by CentralBlvd08; May 10, 2008 at 10:36 PM. Reason: Automerged Doublepost
Old May 10, 2008 | 10:37 PM
Switt23's Avatar
possibly the pump flooded all your meth while the car shut off? Sounds like the car is chugging water or in this case meth.
Old May 10, 2008 | 10:42 PM
AEM progressive contoller is flashing red
How do i fix?
I think so it flooding becuase i here liek a swoooshhh where my intake is and the pump is goin crazy with the car off do i jsut wait it out or what
Last edited by CentralBlvd08; May 10, 2008 at 10:46 PM. Reason: Automerged Doublepost
Old May 10, 2008 | 10:44 PM
D4u2s0t's Avatar
where are you in jersey?
Old May 10, 2008 | 10:48 PM
Jackson ocean county
Is there a way i can fix this ?
Last edited by CentralBlvd08; May 10, 2008 at 10:48 PM. Reason: Automerged Doublepost
Old May 10, 2008 | 10:54 PM
RooTBeeR's Avatar
stop cranking the engine b4 you break it, and pull your plugs, check your dipstick, see if some of your meth has leaked passed the rings into the oil pan.
Old May 10, 2008 | 11:18 PM
no leakage anywhere in engine bay pulled dip and its fine
not sure what else
Last edited by CentralBlvd08; May 10, 2008 at 11:18 PM. Reason: Automerged Doublepost
Old May 10, 2008 | 11:24 PM
RooTBeeR's Avatar
is it able to crank over, does it lock up? does it turn over slugishly?
Old May 10, 2008 | 11:25 PM
it turns on and runs but there is white smoke coming out, when i hit the gas my meth light is automaticlly activated which mean meth is spraying but i can rev and turn on and off
Old May 10, 2008 | 11:27 PM
INFE's Avatar
nothing to do with the meth but it sounds like you blew the head gasket. Thats the only way white smoke would be coming out.
Old May 10, 2008 | 11:28 PM
Sunburst_SS's Avatar
do you have a check valve on the meth line?
engine coolant level good?
Old May 10, 2008 | 11:32 PM
have no idea like i said my meth tank was full now its not.
Old May 10, 2008 | 11:33 PM
you don't know if you have a check valve in the meth line to your engine?
Old May 10, 2008 | 11:36 PM
Im sure i do its the AEM METH KIT
Old May 10, 2008 | 11:40 PM
so the pump is running when the car is off? You check the wiring?? If you have a power wire shorted to ground or something it could kick the pump on.....
Old May 10, 2008 | 11:58 PM
i didnt do the install went to a shop to do it
so not sure, never did this before first time it let it go liek that.... all i know is the meth went some where and its not on the ground
about 2 and half courts gone
im stumped
Last edited by CentralBlvd08; May 10, 2008 at 11:58 PM. Reason: Automerged Doublepost
Old May 11, 2008 | 12:02 AM
RooTBeeR's Avatar
yeah, white smoke = burnt oil. Does your exhaust smell like burnt oil?
Old May 11, 2008 | 12:10 AM
yea pretty much i think
do i need to get this fix professionally or should i jsut let the car run?
Last edited by CentralBlvd08; May 11, 2008 at 12:10 AM. Reason: Automerged Doublepost
Old May 11, 2008 | 12:15 AM
RooTBeeR's Avatar
you're not sure? Yes, if it's burning oil, then it usualy is serious.
Old May 11, 2008 | 12:44 AM
no idea man like i said engine is lean only thins is all my meth is gona and its not on the floor the exhaust smoke doesnt smell like gas or oil but like a fum onyl thing i can explain in liek the smoke from pot holes smells like meth pretty much
just cant figure at why my tank is just gone
Last edited by CentralBlvd08; May 11, 2008 at 12:44 AM. Reason: Automerged Doublepost
Old May 11, 2008 | 01:40 AM
2K5SS/SC?'s Avatar
Where is the meth jet located? Is it before or after the supercharger?
Old May 11, 2008 | 01:43 AM
before drilled into the intake started it and tried to take it around the block and it start bogging when i got over 3 k like it wanted to shut off it isnt think white smoke it comes out and dispaeares jsut white whne coming out of exhaust but as soon as it start leave the exhaust its gone
Old May 11, 2008 | 01:59 AM
2K5SS/SC?'s Avatar
Did you pull the intake coupler to see if the meth settled in the intake? It may have also flowed down and soaked your filter as well causing you MAF to ge wet. Check all the intake parts, dry your filter, and spray out your MAF with CRC MAF cleaner. Then get back to me. If the smoke is is still coming out white after a few minutes of the car running, then you might have bigger problems. What ever you do, do not refill your meth bottle until we figure out what the problem is.
As a side note I have a funny feeling your checkvalve or solenoid has failed. Not sure what one the AEM kit uses, but that is my guess here.
