Help!!
Old Aug 21, 2008 | 10:15 AM
Z06vettespd's Avatar
Help!!
I was wondering if there was a thread on how to install a 2.8inch pully and belt? If anyone could help that would be awesome. Thanx
Old Aug 21, 2008 | 10:17 AM
EdCobaltSS's Avatar
you have to pull the belt off, then remove supercharger and have a pulley remover/installer tool in order to change pulley and new hub.
Old Aug 21, 2008 | 10:18 AM
D4u2s0t's Avatar
well, if you have a pully that will fit on your hub it's pretty simple. take out the bolts that are holding the pully on, take off the pully, put on the new pully, and then tighten the bolts.
as far as the belt, easiest way is just to look and take a few pictures as far as where the belt goes around which parts. there is a tensioner below the pully that you can turn, and will give you some slack.
may be easier with pics, but that's the general idea. but regardless, take some pictures of where the belt runs in the car so that you can match it up.
that's only if he has to install the hub as well though. it he already has a hub on there there's no need for a pully puller.
Old Aug 21, 2008 | 10:20 AM
Awesome! Thank you guys very much!
