help!!
Old Oct 6, 2008 | 10:13 PM
ACESSbalt's Avatar
help!!
so i recently swapped out my blower and added a boost gauge and now the car runs like **** seems really slow and the boost gauge only reads 5 psi so maybe theres a vacuum leak or something i really dont know ran great before the swapping of blower and change the gauge lmk what you guys think
Old Oct 6, 2008 | 10:17 PM
compucarnut's Avatar
not enough info. But you have a boost leak somewhere. Probably a gasket or vacuum line.
Old Oct 6, 2008 | 10:32 PM
ACESSbalt's Avatar
i cant provide enough info thats all i know thats why i cant find out whats goin on
Old Oct 6, 2008 | 11:15 PM
NexTnmE's Avatar
X2. Not to be a dick...but if YOU can't even narrow it down, how are we going to?
Gasket, vacuum hose, did you mess with the injectors, electrical connections, go over step by step what you did...you will find it.
Old Oct 6, 2008 | 11:41 PM
Xtremeskwerl's Avatar
Grab a can of starting fluid and spray it over where the vaccum lines or gasket leak could possibly be (near the supercharger etc etc) if the rpms pick up there is your leak.
Old Oct 7, 2008 | 03:37 AM
theneelster's Avatar
A vac leak at the boost gauge t isn't going to make your car run extremely crappy (just moderately crappy). I'd say that you bunked your supercharger gasket or your blower swap was for one that is fubarred.
5 psi means you've got a leak somewhere it's just a matter of where.
Old Oct 7, 2008 | 03:46 AM
blu3_v1p3r's Avatar
did ytou swap the supercharger with the the same type, or a differnt one. If I was a different one it could be your tune.... as for what he said about the gasket... since you took one s/c off and put another one on if could very well be your gasket is where leaking is coming from. The more info you can come up with the better
Also i would say try puting the other blower back on and see what you get...
Old Oct 7, 2008 | 03:49 AM
He probably ported it. You don't need a tune for a port/polish of the s/c generally speaking. But he is lucky because stagemeier is in st. louis as I remember it. If the s/c is fubarred he can fix it no problem.
