Help!!!!!
Help!!!!!
Hey guys i have work soon and my car wont turn over.
04 redline. unplugged the negative terminal to the battery in the trunk in attempt to reset the pcm since it was running a cel for misfire. Anyway, when i went to start the car back up, all electronics work, stereo etc, but the car will not turn over...wont even try...
any thoughts? just started with ease 5 minutes ago...???
put it in neutral start pushing like hell run hop in put it in first let off the clutch real fast and pop it. everything should catch and it'll start, give it some gas then it should be fine then go get the battery checked out when you have the chance.
Thank you, yes it was on. Since I unplugged the battery it restated the PCM and it just needed time to re learn. 10 minutes and it fired right up. How young are members getting on this site? Lol wanting me to clutch pop my car lmao, I'm not that desperate.
I pushstarted mine... once... just to see if It could be done, so that I'd know if I was ever in a situation where I would need to... It worked... well it wasnt so much of a push start as it was a let it roll down the hill driveway start.
