Help!!!!!!
Old Oct 7, 2012 | 11:55 PM
Bad-A-SS's Avatar
Would there be anything else I should replace or change while I have it off?
Old Oct 11, 2012 | 12:25 AM
Bad-A-SS's Avatar
Hey guys just wanted to update yall with the clutch job..............ITS DONE................I know I know Im a BAUS. But seriously that was a hard job. My neighbor and I started late last evening and got finished at 10 tonight. I love the way that GMPP upgraded clutch feels so much smoother and with the OTTP Trans mounts WOW the driving experience is so much better even with the slight vibration coming from them. The car seems planted to the ground more and the IC Pump is working amazing so happy with this successful week. If y'all guys have any ?s about how I did a specific thing just ask as I am now a little more knowledgeable hahaha Thank y'all for the help though seriously
Old Oct 11, 2012 | 11:49 AM
SaberD's Avatar
Originally Posted by bluebalt07
Yes you need a torque wrench. It's not hard to do on jackstands. And fluid is needed if you pull out the axles because the fluid will drain out through the differential. If you leave the axles in you shouldn't need fluid but it doesn't hurt to change it while you're in there
i only lost a few drops of fluid when I pulled my axles. I plugged them up with shop towells while they were out and then topped it off when I got everything back together. thanks op for telling us your results!
Old Oct 13, 2012 | 04:25 PM
Bad-A-SS's Avatar
No problem like I said if anyone needs advice i'm willing to help
