Help Asap
Old Apr 15, 2007 | 03:48 PM
OverDrive07's Avatar
Help Asap
Whats a way to remove the stock supercharger pulley without a pulley puller. I rented one from autozone but theres no way it works. Is there anyway to remove it without a pulley puller that would work?? I need some help please.
Old Apr 15, 2007 | 04:01 PM
06blackg85ss's Avatar
nope.... sorry.. need a pulley puller... and one that will work with the s/c with a centering pin
Old Apr 15, 2007 | 04:05 PM
chevysalesman614's Avatar
i used a gear puller that i rented from pep-boys
Hopefully someone who has the zzp puller lives near you.
i think you should just put the blower back on and wait till you get the right tool. you don't wanna damage the supercharger
Last edited by chevysalesman614; Apr 15, 2007 at 04:05 PM. Reason: Automerged Doublepost
Old Apr 15, 2007 | 05:09 PM
idunn's Avatar
dealer ftw
Old Apr 15, 2007 | 05:16 PM
I have a pulley puller if you want to travel into Queens
Old Apr 16, 2007 | 12:10 AM
Thanks.. I went to a shop and had them rig up a clamp type system that involved an air gun. the air gun basically fit into the socket at the end of the clamp and then when he fired that bad boy up it pulled the clamp which was connected to the pulley and pulled the pulley off. I which i could describe the tool better than a clamp because it was more complex than that but it worked with no problem. Thank you though guys
I went to a motorcycle customize place and they had the tool that was perfect for the job.
Last edited by OverDrive07; Apr 16, 2007 at 12:10 AM. Reason: Automerged Doublepost
Cobe
Sep 19, 2015 11:04 AM
06noscobaltss
May 25, 2006 01:55 PM
Saki XL
May 16, 2006 01:34 AM
9JordonFlex9
Mar 26, 2006 08:05 PM
Cobalt30
Mar 11, 2006 02:50 AM
