Help!!! Interceptor Problem! Fast plz!
Old Oct 7, 2008 | 02:03 PM
FryLoch's Avatar
Here's what is going on, the gauges supposedly have to use a jump wire to start up when you start the car. It's suppoesed to be the red wire in the center of the bottom port on the back of the interceptor. I have wired these into a wire that is hot only when the key is on, this is the red wire coming out of the factory boost gauge. Now when I plug the gauges in the fuel pump starts up as well as some other things. I start the car and when I turn the key off it keeps running. As soon as I unplug the gauges the car goes back to normal and shuts off... The gauges are functioning without the jump wire, but I have to unplug and plug them back in every time...
What is the problem here? Is my accessory wire? Should I not use that boost gauge wire?
what accessory only circuit should I use?
Old Oct 7, 2008 | 02:11 PM
Omega_5's Avatar
There is a jumper on the back of the gauge. Pull that jumper off!
And next time... read the manual first.
all4glh's Avatar
Try the sunroof fuse if you have it, or radio fuse. See if changing it from the boost gauge wire to the accessory wire helps. If not, report back. Oh, and don't forget to do it properly and use the mini add a fuse from autozone for $6.
Old Oct 7, 2008 | 02:12 PM
FryLoch's Avatar
I didn't get one and the online manual is useless, where is the jumper on the obd2 port I keep hearing about.
Old Oct 7, 2008 | 02:15 PM
Omega_5's Avatar
Not on the port... on the gauge.
Old Oct 7, 2008 | 02:18 PM
FryLoch's Avatar
Is it the little red pointy thing in the back?
Old Oct 7, 2008 | 02:20 PM
tombomb's Avatar
yes it pulls out mush like a fuse
Omega_5's Avatar
Yes.
And FYI, it was the bold part on page 4 of the online manual.
Old Oct 7, 2008 | 02:24 PM
95cam86roc's Avatar
subscribed since i've yet to fully wire my gauge....
Old Oct 7, 2008 | 02:29 PM
FryLoch's Avatar
Hurray! It's fixed... frankencobalt is no more...
Old Oct 7, 2008 | 02:31 PM
95cam86roc's Avatar
How did you finally hook it up?
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
nathan112i
Sep 30, 2015 07:12 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
