Help...losing coolant
Old Aug 26, 2010 | 02:17 AM
~Mike~'s Avatar
Ok, to start off I've never upgraded the car past stick boost. Badmab header and intake are the only mods unless you wanna count the dp and crapback I have.
I'm losing coolant somehow and I'm not sure the cause. I've been told head gasket and possibly leaking laminovas and just wanna get some more input before I tear it apart. I would say in a 3 week period the coolant tank has emptied completely. I was letting it go until this point to see how fast its disappearing. I say disappearing because there are no puddles under my car ever and I'm also not blowing any smoke from the tailpipe. Oil also smells like gas, though I'm told this can "just happen to some cars". Anyone have ideas besides the head gasket or laminovas that may be getting overlooked or encountered a similar problem to mine? I haven't got a lot of time to put into fixing this issue as its my daily and I can't have my car torn apart for a week or more.
Old Aug 26, 2010 | 02:22 AM
boost_junkie16's Avatar
Pull your oil cap and see if there is a yellow-ish foam on the bottom of it. Or try getting it up to operation temp and let it sit idling somewhere for a bit then move it and see if there is any puddles..
Old Aug 26, 2010 | 02:27 AM
~Mike~'s Avatar
Done both, no film/foam stuff and no puddles after a stop. I'm at a complete loss here, its got to be going somewhere?
Old Aug 26, 2010 | 08:44 AM
383_Stroker's Avatar
Which coolant system is it?.. The Engine Coolant or the Heat Exchanger system coolant?
Laminovas and Headgaskets aren't part of the same system.. =)
Old Aug 26, 2010 | 08:49 AM
BoostedYards86's Avatar
truth completely seperate systems.
Old Aug 26, 2010 | 10:34 AM
Nacademus's Avatar
I was losing coolant from the intercooler circuit, bled through pinholes in my laminovas. Got the intake replaced under warranty. You may have the same issue.
Old Aug 26, 2010 | 11:18 AM
~Mike~'s Avatar
Well, I'm not sure which one it is leaking lol the resevior by the fuse box is what I filled up and the filler neck down front never seemed to get below the full line.
Old Aug 26, 2010 | 11:24 AM
06_SIC_SS's Avatar
without looking like a tractor i say its not a headgasket out of personal experience.. or piston ring.. if theres no blue smoke etc
Old Aug 26, 2010 | 11:36 AM
rnjmur's Avatar
I am guessing that you have a small headgasket leak. It isn't enough to cause smoking or visibly show in the oil, but if you take a sample of oil and have it analyzed I bet you will have a good amount of coolant in there.
Old Aug 26, 2010 | 12:29 PM
mrbelvedere's Avatar
pull the valve cover and look under it i had the same problem as you did never shown in the oil cap but when i pulled the valve cover there was the evidence of the leaking hg
Old Aug 26, 2010 | 01:00 PM
06_SIC_SS's Avatar
^^^ good info right there
Old Aug 26, 2010 | 01:34 PM
WickedSS2005's Avatar
Head gasket. I told ya this weeks ago bro lol
Old Aug 26, 2010 | 02:10 PM
~Mike~'s Avatar
Yes, I know lol but then the coolant stopped disappearing. Then yesterday, popped the hood and the entire resevior was drained.
Old Aug 26, 2010 | 03:18 PM
rnjmur's Avatar
I had the same problem with my LSJ. I would go a month and add like 1/4 a quart of coolant. Then I would check it 2 weeks later and have to add a quart, then 2 weeks later it would still be full, then a week later half a quart low again. My oil analysis showed high amounts of coolant in the oil, but when taking it for warranty work they wouldn't do anything. Apparently "losing" a quart or more of coolant is OK and not warrantable for GM, oh and they will not do any warranty work based on oil analysis, GM says oil analysis give you "false" information... LMAO!
Disclaimer: I am not dissing the GM mechanics in any way. It is the dealership and GM corporate that don't want to pay for warranty repairs that are the problem. There are plenty of good GM mechanics out there.
Old Aug 26, 2010 | 04:32 PM
Nacademus's Avatar
The IC circuit will drain under heavy boost- if your laminova is leaking.
Old Aug 26, 2010 | 05:27 PM
he isent talkig about his ic circut
Old Aug 26, 2010 | 05:29 PM
Not from the Coolant reservoir. The fill neck is a closed system NOT connected to the engine coolant in any way. The reservoir should not drain unless there is an issue
Old Aug 26, 2010 | 05:32 PM
ecot3c inside's Avatar
are you checking after your engine is pretty hot? because that will bring down your coolant quite a bit as opposed to checking it cold..
is this a trick question?
Old Aug 26, 2010 | 05:34 PM
Nacademus's Avatar
Sorry, I misunderstood.
Old Aug 26, 2010 | 09:14 PM
~Mike~'s Avatar
Checked coolant both hot and cold. Was dead empty after sitting overnight. Not trying to be a smartass towards you but I'm not dumb, I know how to check fluids lol
Old Aug 26, 2010 | 11:10 PM
06cobalt racer's Avatar
have your radiator cap pressure checked. i had the SAME thing happen to me. took them 3 days to find the cap bad.
Old Aug 18, 2012 | 10:54 AM
Shogokuma's Avatar
i have to revive this because im having the same issue, i dont believe there is a radiator cap.. is there? i filled my overflow 3 days ago and now its saying low coolant i had the oil tested and it dosent have coolant in it and i have a compression test and also a leakdown test and they found nothing so i dont know what to do anymore i reall dont want to spend the money on a new HG if thats not the problem?
Old Aug 18, 2012 | 02:35 PM
Tjolley's Avatar
if ur loosing coolant that fast its the head gasket i just did mine a month ago....nothing showed up i all those tests eather...wat is happening is the combustion chamber pressure is leaking into the coolant system and pushing it out the overflow vent tube..
u see the coating missing...wat happened was the head lifted and the coolant washed through coating off the gasket...
Old Aug 18, 2012 | 04:42 PM
Shogokuma's Avatar
those overflow vent tubes are they going back in the system or on the ground?
Old Aug 18, 2012 | 04:54 PM
Tjolley's Avatar
It lets pressure out of the system...at the same time the water goes with it...yes it drains out the bottom of the reservor bottle..look in ur drivers side wheel well u might see water stains running down...just get a cometic hg from zzp and buy a can of coper spray from ur locale auto parts store and arp head studs and a case of beer and dig in..it isn't that hard
