HELP!! MBC... Q's
Old Nov 14, 2006 | 11:37 AM
R33P3R007's Avatar
360 L337 User
Come on people.. Need Some help here.
MBC i Used http://www.voodooboost.com/boost_con...MBC/index.html
I installed this thing where JMC007 and Denny say to. Is there anyone else that has used one that has or can get me pictures of it installed. I have pics in my gellery of the 1000 ways i tried it. but every way i still get 15+ lbs of boost on my interceptor. Could my intercepter be telling me incorrectly because it is ODBII and not manual?
Old Nov 14, 2006 | 11:39 AM
johnkb8's Avatar
i think the guage is working just fine, i think something is going on with this "Manually Boost Control" thingy whatcha macallit
Old Nov 14, 2006 | 12:03 PM
R33P3R007's Avatar
360 L337 User
yeah. but if the gauge is showing what the computer shows. then is it really making what it says. i don't know, i am just trying to figure out what my problem is.
Old Nov 14, 2006 | 12:04 PM
R33P3R007's Avatar
360 L337 User
Old Nov 14, 2006 | 12:06 PM
R33P3R007's Avatar
360 L337 User
Old Nov 14, 2006 | 12:07 PM
R33P3R007's Avatar
360 L337 User
Originally Posted by Jmc007
Counterclockwise all the way out will gives you 12 PSI like if there wasn't any MBC. Full clockwise will gives you the max PSI that the supercharger pulley can give.
All that supposing that the MBS is installed on the right hose, the one between the by-pass valve selenoid (black rectangular box) and the by-pass valve actuator (balck cylindrical device on the supercharger).
Hope this help.
Thie is what I have so far
Old Nov 14, 2006 | 01:12 PM
2K5SS/SC?'s Avatar
It looks like in the last pic, you have the right hoses, but the controller is backwards. It should go into the bottom part from the black box, and then out the side to the bypass valve.
I hope you didn't pay to much for that thing, as you can easily tell it's just a brass "T" from the harware store with the valve/knob in one end painted black. You could have made it for like $3-$5 bucks.
Old Nov 14, 2006 | 01:42 PM
R33P3R007's Avatar
360 L337 User
well. i got it and hardware shiped to me for 19.00.
Old Nov 14, 2006 | 02:16 PM
soccer1061287's Avatar
What pulley are you running on the SC? We sell the perrin MBC and have never had a comeback on one. If you are interested, you can check it out at highperformanceoutlet.com. I am getting about 17 psi on mine.
Old Nov 14, 2006 | 02:20 PM
R33P3R007's Avatar
360 L337 User
I am running the 2.9 I am going to run the 2.7 but i want to make sure the MBC works before going down to the 2.7.
With it installed like 100 ways i still read 15+ it was wet out still last night so i didn't get on it all the way to the top, but i usually see 15.5 to 16.1 all the way up there in 3,4, and 5 at 600rpms and up. Aren't i supposed to only see 12 with it all the way out.
Like i said, could it be that my gauge takes the boost from the computer. not manually.
I don't know what else to try.
Old Nov 14, 2006 | 02:32 PM
I am pretty sure that your gauge is giving what the engine is producing, but if you want to verify, buy a cheap pressure gauge and tee into the line, then just tape it to the cowl where you can see it. It is quick and dirty, but will answer that question once and for all. Just out of curiousity, what are you running for an intake?
Old Nov 14, 2006 | 02:40 PM
R33P3R007's Avatar
360 L337 User
Stock. with airbox mod. k&n no airbox cover
cti 3 inch header and catted downpipe to stock catback
Old Nov 14, 2006 | 02:41 PM
R33P3R007's Avatar
360 L337 User
where is the manual Boost controller on that site. i cant find it.
Old Nov 14, 2006 | 10:57 PM
R33P3R007's Avatar
360 L337 User
help god dammit bump.
Old Nov 15, 2006 | 08:17 AM
johnkb8's Avatar
bump, because we installed this thing in my gargae, now come on!!!, somebody has to know how to work thing piece of crap!
Old Nov 15, 2006 | 08:19 AM
R33P3R007's Avatar
360 L337 User
i thought it was the gauge. but jmc is using the same as I am, and denny is using the stock one. Maybe tonight i'll try my stock one.
Old Nov 15, 2006 | 01:12 PM
We don't have the Cobalt page put together on our site yet, but as far as the MBC's go, I checked last night and we have both the Perrin and the TurboXS in stock. The TurboXS is available in about 3 different configurations. Just look under the EVO or STI pages and you should find them.
Old Nov 16, 2006 | 12:43 AM
R33P3R007's Avatar
360 L337 User
can i skip the by-pass valve selenoid al together. my buddy who is crazy into DSMs.. and turbo ****. told me to skip the by-pass valve selenoid and connect the line directly from the manifold (the one that goes to the firewall side of the by-pass valve selenoid) to the by-pass valve actuator (balck cylindrical device on the supercharger) he said this will let me run "spring rate" and i shoulod only see a few pounds. well i did. and it worked, on my boost gauge i was only getting like 3.8 WOT in 2nd and before i was getting 15+
i drove it around a few minutes and got no cel or anything. since i never disconnected the plugs to the by-pass valve selenoid.
Is this safe to install the MBC there, and use that to tune the boost. or do i need to go through the by-pass valve selenoid
Old Nov 16, 2006 | 12:46 AM
R33P3R007's Avatar
360 L337 User
could my MBC be bad as well as the other one i tried.
Old Nov 16, 2006 | 07:24 AM
If you bypass the by-pass valve (no pun intended), you are solely dependent on the MBC to control boost and I am not 100% sure that it would handle any boost spikes that could occur. This is getting to the edge of my comfort level with regard to specific knowledge with the bypass valve, so take these comments with a grain of salt. If anything, I am trying to be conservative here.
Old Nov 16, 2006 | 08:27 AM
R33P3R007's Avatar
360 L337 User
Thanks. I think it would be the same as just doing the Boost bypass mod. But instead of plugging the line so the motor doesn't bleed boost. installing the MBC so i can limit the boost and run the 2.7
Old Nov 16, 2006 | 09:33 AM
johnkb8's Avatar
bzzzzzzzzzzzzzzzzzzzzzzzzzz ump
Old Nov 16, 2006 | 11:43 AM
R33P3R007's Avatar
360 L337 User
BUMP.. bump.. bumpbump..... come one someone knows.
Old Nov 16, 2006 | 08:45 PM
Your logic makes sense. Like I said in my PM, you are somewhat charting new ground here and the consequences can be costly if the wrong thing happens.
Old Nov 17, 2006 | 08:35 AM
R33P3R007's Avatar
360 L337 User
morning bump for all the people i pmed that have yet to give me $.02
