Help me!!!!!!
Old Oct 31, 2012 | 01:26 AM
Bad-A-SS's Avatar
Originally Posted by mrbelvedere
it could be the winter blend fuel causing the knock do comp test and a leak doown test where is hickory
Hickory is in North Carolina why do you ask?
Old Oct 31, 2012 | 10:04 AM
mrbelvedere's Avatar
just wondering
Old Oct 31, 2012 | 10:05 AM
Bad-A-SS's Avatar
I'm only seeing knock when I take off now
Old Oct 31, 2012 | 10:14 AM
user 72239's Avatar
how much?
Old Oct 31, 2012 | 10:27 AM
Bad-A-SS's Avatar
Usually.3 to 1 but when I left class today I saw one knock of 2.1
Old Oct 31, 2012 | 10:43 AM
user 72239's Avatar
Does it go away slowly or instantly?
Old Oct 31, 2012 | 10:48 AM
Bad-A-SS's Avatar
It goes away instantly why?
Old Oct 31, 2012 | 10:51 AM
well from the looks of a couple of your plugs you may be getting oil in the cylinder i would do a comp test and a leakdown test
Old Oct 31, 2012 | 10:53 AM
user 72239's Avatar
if it goes away instantly it is most likely false knock.
Knock sensors are really really sensitive, and they detect a certain sound frequency that the computer determines is "knock" and then retards the timing.
However, if something is banging up against the block or matches that sound frequency it will show false knock. the PCM is designed to pull timing slowly and usually at .7 per second. so if you were getting true knock and you had 3.0 it would go 3.0...then 2.3...then 1.6...then .9 and so on till it goes away.
False knock will show knock, then disappear completely. At least thats how It was explained to me.
However, I would recommend doing a compression test just to make sure.
Old Oct 31, 2012 | 10:54 AM
Bad-A-SS's Avatar
I have a video of it running should I will upload it
Old Oct 31, 2012 | 02:25 PM
  #36
Bad-A-SS's Avatar
Couldnt get it to upload guys gonna do a compression test n will load results
Old Oct 31, 2012 | 04:34 PM
  #37
Bad-A-SS's Avatar
Ok so it sounds like I have false knock. So then what would cause the big decrease in boost? Would the bypass valve maybe cause this
Old Oct 31, 2012 | 08:05 PM
  #38
Bad-A-SS's Avatar
Nvm guys it still boost the same if not actually a little more I guess I just freaked when it bogged down on me a little. It is really ******* cold here so Im figuring that is affecting my vaccum and boost a little but I will keep things posted if something does happy. Thanks everyone
