Help with meth
Help with meth
Ok so I have the devils own meth kit and on the controller the yellow light that comes on when it is spraying full mist it is blinking what does this mean if I shut the car off it will reset and work fine but then it will come back
I don't know about the devils own kit, but the AEM kit...the blinking means different things. One blink means low meth...2 blinks is like an open in the pump...3 is like a short or something...
The old controllers read a tad off. It blinks a bit when you get close to the pressure you have it set to come on full. You might have the controller set to a pressure point that your boost does not reach. Just off a couple pounds...
turn your dial back a bit, see what happens...
Maybe there's a power interuption between the controller and constant power.. It could be continually shutting down and powering up, then reading the MAF sensor, doin it's blinky "reading the bars on the sensor", shutting down.. and going thru the method again.. and again.. and again...
I'm grabbin straws, yea... lol
i know thanks for the input i'm hoping i just ran it out of meth cause i had'd filled it up in awhile and it might have just run the pump dry i don't know but it's been working fine the past 2 days i'm just worried cause i'm getting retuned and dyno'd this weekend don't wont this problem on the rollers
Do what I did wire in an led to a electric float that you mount in the meth tank to tell you wheen your low, I also have another led on my dash wired to the pump to let me know when im spraying so I don't go into PE without the pump on, im currently working on a relay that taps into the boost solenoid and cuts boost if the pump doesn't kick on.
no i'm not i'm getting the car retuned and dyno'd this weekend
ur gayyyyy (this is sort of a depressing monotoned gay bash. kinda trailing off and getting more subtle as it gets drawn out. imagine me doing it with a sad look on my face)
Call me so i can go over this with you. will take afew minutes over the phone or way to many back and fowarths on this forum. 405-470-4356 or you can pm your number and i will call on my dime .
