Help please!
Old Aug 22, 2008 | 07:51 PM
thatotherguy's Avatar
Help please!
I just changed out my starter and i thought that was the problem. but still there is no crank when i turn the key all the way. what else do youll think the problem is?? alternator? bad ground wire?
Old Aug 22, 2008 | 08:34 PM
YellowRocketSS's Avatar
You checked all fuses and relays... Make sure you have power at the starter. and check the signal wire
Old Aug 22, 2008 | 08:41 PM
I already checked the starter.. before when it was clicking there was alot of sparking around the starter. the guy that build my engine didnt put all the wires back where they were supposed to be. like theres some kind or ground on one of my tranny or oil pan bolts. stupid ass people. But i really dont know what to do right now. all the lights come on and i changed the battery already so its gotta be one of the ground wires somewhere on the starter and the problem is i dont know which one goes where now. theres a ground wire that has a red rubber peice thats going to one of the starter bolts and then theres a little ground wire going to the smallest bolt.
Does anyone have pictures of the starter and where the ground wires go on it??? I really need some help on which ground wires goes where
Last edited by thatotherguy; Aug 22, 2008 at 08:41 PM. Reason: Automerged Doublepost
Old Aug 22, 2008 | 08:42 PM
can u get pics?
Old Aug 22, 2008 | 08:44 PM
Nope i dont have a camra i live with a few of my friends.. the only thing we dont have lol
Old Aug 22, 2008 | 08:46 PM
oh lol ya that would make it alot easier for us to get u help lol. Do the posts look like there certain sizes?
Old Aug 22, 2008 | 08:50 PM
what do you mean? if your talking about the start theres 3 bolts one small one and 2 big ones, and the red ground wire is one of the big ones and the other one is on one of my tranny bolts, and then theres another small ground wire which is on the smallest bolt
Old Aug 22, 2008 | 11:41 PM
theneelster's Avatar
I'm going to say it's still starter related.
Old Aug 22, 2008 | 11:50 PM
copson20's Avatar
Service and Repair
STARTER MOTOR REPLACEMENT
REMOVAL PROCEDURE
1. Disconnect the negative battery cable.
2. Raise and support the vehicle. Refer to Vehicle Lifting.
3. Disconnect the electrical connectors (3, 4, 5) from the starter.
4. Remove the starter bolts.
5. Remove the starter.
INSTALLATION PROCEDURE
1. Install the starter.
2. Install the starter bolts. NOTE: Refer to Fastener Notice in Service Precautions. Tighten the starter bolts to 40 N.m (30 lb ft) .
3. Connect the electrical connectors (4, 5) to the starter. Tighten the battery terminal nut to 17 N.m (13 lb ft) .
4. Connect the S-terminal connector (3) to the starter. Tighten the battery terminal nut to 3 N.m (27 lb in) .
5. Lower the vehicle.
6. Connect the negative battery cable.
Old Aug 22, 2008 | 11:52 PM
Originally Posted by copson20
Service and Repair
REMOVAL PROCEDURE
It's also on the ecotec build pdf.
Old Aug 23, 2008 | 03:43 PM
whats the chances that the ign. fuse blew??? because i had alot of clicking noise and then it stopped and there was no power to the key when i try to crank it. i still have all lights and everything
