Helpp!!
Old Sep 28, 2008 | 01:48 AM
2006sssc's Avatar
Helpp!!
Hey guys looking into buying a cobalt..the guy says it has stage 2 was wondering how i can find that out??? and also the car has air ride would that make or break my handling let me know
Thanks in advance
Jordan
Old Sep 28, 2008 | 01:50 AM
boostaddict's Avatar
when you drive the car, if it boosts to 15, it's stage 2. if it boosts to 12 it's stock
as far as bags, I don't know anything about them
good luck man
Old Sep 28, 2008 | 01:51 AM
2006sssc's Avatar
good luck man
ok cool thanks.. now is there a way he could have just put a smaller pulley so it can boost that high?
Old Sep 28, 2008 | 01:57 AM
EXsoccer1921's Avatar
look at the pulley itself i think it might say stage 2. not sure. also ask him what injectors are in it. and don't be like hey the stage2 has 42# injectors what does this have. just say "hey so it has a smaller pulley on there, did you upgrade the injectors as well"
as for air ride. i've heard mix oppinions on it. but either way. i'm almost 100% its not track legal
yeah he could have done that but I highly doubt it. the stage 2 kit consists of the pulley and bigger injectors. he would be nuts to run 3 more pounds of air with no fuel. that motor would hate him
also, if he put on a legitimate GM stage 2 kit, not a custom setup, the bolts that come with the kit for the pulley are blue. can't miss them
Old Sep 28, 2008 | 02:02 AM
yeah i knew there was something different about the bolts but i couldn't put my finger on it. and what i meant by asking him about the injectors that way is that by "playing dumb" it will let you know if hes bsing you or not. if he says no its the stock injectors, then its more than likely not a stage2. but if he says yeah the stage2 come with a smaller pulley and larger injectors. i'ld buy from him
Old Sep 28, 2008 | 02:04 AM
yeah don't let him know how much information you have. play dumb
Old Sep 28, 2008 | 02:13 AM
2006sssc's Avatar
ok cool that makes sence...i am going to do stage 3 with it most likely..just wondering what i could do for traction problems..as in motor mounts tranny mounts H brace..anything else?? and also was wondering about a LSD any thoughts on that??
Old Sep 28, 2008 | 02:18 AM
I probably wouldn't bother with stage 3 IMO
for traction, you want solid motor mounts from ttr and poly inserts for the trans mounts, also from ttr. click the link in my signature. aside from that, look into clutches and maybe an ingalls torque dampener
and for the lsd, if it doesn't already have one, don't bother. it's hard to find them and you have to rip the trans apart to install it. I don't have one and although I can say I wouldn't mind having one from the factory, it wouldn't be worth it to install it on my own. the cost outweighs the benefit IMO
Old Sep 28, 2008 | 02:20 AM
2006sssc's Avatar
why would you not run stage 3??
Old Sep 28, 2008 | 02:23 AM
because as far as I know it's really just a PCM that's tuned for a 50 shot. you can run that without a tune and if anything I'd go with a custom tune.
Old Sep 28, 2008 | 02:31 AM
OriGinaL Condo's Avatar
Not to mention the Stg3 PCM is locked so you can't even go get a custom tune.
Old Sep 28, 2008 | 02:37 AM
^^^^x2 forgot about that
stage 3 ftl
Old Sep 28, 2008 | 02:42 AM
2006sssc's Avatar
ok so then what should i do??..and i want the 50% boost in 1st that would help alot..give me your ideas guys
Old Sep 28, 2008 | 05:57 PM
Zach06CobaltSC's Avatar
what are your plans for the car, also whats the price tag on this thing, how many miles etc.
Old Sep 28, 2008 | 05:59 PM
get on it's Avatar
air ride = heavy...... heavy = bad.......
Old Sep 28, 2008 | 06:06 PM
EatonTVS07's Avatar
^look he's on again lol. but gotta go with forrest, i've heard for every extra 100lbs isa tenth of a second of your quarter mile not to mention li 5-10% fuel economy, don't quote me
Old Sep 28, 2008 | 07:30 PM
get on it's Avatar
get the vin and call gm. they can give you the dealership it came from then call the dealer and ask what was done to it such as your stage 2. they might say they cant give out the info but if you just let them know that you are purchasing the car they will tell you the performance mods from dealer
Old Sep 28, 2008 | 07:58 PM
theneelster's Avatar
Thanks in advance
Jordan
Bags aren't necessary on our car...I would think it'll make the ride softer when it needs to be tighter, but I don't know.
You don't want 50% boost in 1st and/or 2nd.
Last edited by theneelster; Sep 28, 2008 at 07:58 PM. Reason: Automerged Doublepost
Old Sep 28, 2008 | 09:58 PM
2006sssc's Avatar
my plans are as follows...
Stage 3
50 shot
2.8 pulley
60 lb injectors
full 3' exhaust
downpipe
bigg front mount
meth
then traction problems come
Give me ideas
Old Sep 28, 2008 | 11:10 PM
no stage 3 because the pcm is locked and you wont be able to tune it.
Old Sep 28, 2008 | 11:29 PM
Stage 3
50 shot
2.8 pulley
60 lb injectors
full 3' exhaust
downpipe
bigg front mount
meth
Give me ideas
As stated: stage 3 pcm can't be tuned so there's no point in running 60lb injectors. You can run the 2.8 on a stage 2 or stage 3 pcm without excessive lean. 3" exhaust is worthless on a non-turbo redline er...cobalt ss sc.
Old Sep 29, 2008 | 01:30 AM
raptors_67's Avatar
You can see the injectors underneath the fuel rail. If the tops are green they are stock.
Old Sep 29, 2008 | 01:29 PM
2006sssc's Avatar
cant i get a custom tune?? and not use their pcm?
Jimmy Beilfuss
Jul 11, 2015 05:21 AM
rdskns432
Nov 11, 2011 01:21 PM
joe0016
Feb 2, 2010 12:07 PM
