hesitation
Old Mar 25, 2007 | 11:10 PM
supersexycobalt's Avatar
hesitation
i have some hesitation in second gear anybody know what the problem could be
Old Mar 25, 2007 | 11:26 PM
Johnboy12358's Avatar
You should be more descriptive...
Old Mar 25, 2007 | 11:31 PM
at higher rpm's in second gear only it feels like the car has hesitation
Old Mar 25, 2007 | 11:32 PM
Asrau's Avatar
I had the same problem it's ok, took me forever to try and explain it and get it fixed. Go to http://tis2web.service.gm.com/tis2web enter your VIN and see if the Engine Performance module contains any new flashes for your VIN, should have new calibration for idle surge, etc, etc. Go to the dealership and tell them to update your PCM with that new Engine program module and ta-da fixed!
Old Mar 25, 2007 | 11:47 PM
i dont see anything on there for engine performance module
Old Mar 26, 2007 | 07:39 AM
DTM2188's Avatar
What size pulley do you have? Are you stock? Need a little more info.
Old Mar 26, 2007 | 10:32 AM
i still have the stock pulley on the car but i have a K&N intake, catback exhaust and stage 1
Old Mar 26, 2007 | 10:33 AM
lsjwannabe's Avatar
get it reflashed by gm
Old Mar 26, 2007 | 10:48 AM
remusfighter's Avatar
mine does this when its cold and i just start it.
Old Mar 26, 2007 | 12:34 PM
The Sunburst Kid's Avatar
Yes, there is a reflash for the stages. It pertains to ac load and what not. The new flash will make it all better.
Old Mar 26, 2007 | 12:46 PM
Ryuu600's Avatar
Ok I am confused. Does this sight list things that need to be done only or what. I have stuff listed for my VIN under every section. How do I read this site?
Old Mar 26, 2007 | 07:24 PM
i got my car reflashed when i got the stage 1 installed
Old Mar 26, 2007 | 07:36 PM
Boosted_SS's Avatar
had the same problem about a week ago when it was raining and it was a little bit of moisture in the intake. it dried out a day leter and it was perfect!
Old Mar 26, 2007 | 08:02 PM
NLCobaltSS's Avatar
I have hesitation when it I first start my car, not while idling but when I start driving in first and second gear. Its like a slight delay when pressing the gas and the car responding. This only happens when car is cold. Anyone notice this as well?
Old Mar 26, 2007 | 08:04 PM
bigrroberto's Avatar
Ya me too. If I have time I usually try and let it warm up and then idle down the road in first gear... It goes away fairly quickly.
Old Mar 26, 2007 | 09:01 PM
ImaginaryForce's Avatar
It's caused by moisture being forced through the intake and altering the readings of your mass air sensor. There really isn't any way of stopping it, just be sure to regularly change your filter and clean your mass-air sensor. The oil that come on most filters once the filter is older can build up in the MAF and throw your readings way off ( just did all of this to mine that's the only reason I know it was a problem at least for me )
I was getting a really really bad hesitation and it would throw the occasional van-sized flame out of the exhaust. Cleaned the MAF, fresh filter, and it fixed it right up.
717ssbalt
Oct 2, 2015 04:01 PM
ashalle2
Sep 16, 2015 10:36 PM
Sabon_SS
Sep 7, 2015 12:39 PM
TxLonghorn#1
Jan 28, 2007 09:17 PM
snarkee
Jul 5, 2006 01:57 AM
