high flow cat
Old Feb 18, 2011 | 11:26 AM
willdrew's Avatar
high flow cat
does zzp high flow cat bolt on driectly to bad mab header with no problems??? Also will there be a check engine light???
Old Feb 18, 2011 | 11:32 AM
MoJoJoSSsc03's Avatar
did you search this one? when i have i believe i looked and seen that it should bolt on just fine, and if there is an o2 bong for it to connect to there shouldnt be a light if there is, disconnect battery and see if it comes back... i think some say it has and hasnt.. all depends...
Old Feb 18, 2011 | 11:51 AM
dspeed123's Avatar
Did you mean the ZZP Downpipe with high flow cat? Because if you did then yes it does bolt up directly. You just have to make sure you specify the connection type on the cat back connnection side. Meaning, if you have a stock exhaust you have to select that option or if you have something else you have to be sure to order that type.
Old Feb 18, 2011 | 12:33 PM
willdrew's Avatar
alright kool thanx guys
Old Feb 18, 2011 | 12:43 PM
willdrew's Avatar
Mid length header
Out of curiousity who would u guys say has the best mid header??
Old Feb 18, 2011 | 01:10 PM
dspeed123's Avatar
I don't know, couldn't say because I never used one. I know a lot of people complained about flex conn. and the 2 bolt flange connection. If I were to get rid of my shorty header I would just go long tube but that is just me. I never use 2 bolt flanges anyway, I weld on 3 bolt flanges. I'm done playing with exhaust setups, I had 4 different ones before I found what I liked and it was custom, not one I purchased.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
