High NOx levels what's wrong
Old May 6, 2011 | 10:48 PM
ssblacksc's Avatar
My mods are 42 injectors 2.9 pulley aem cold air intake heat exchanger option b vibrant header catalytic convertor aftermarket exhaust.
I can't pass Ohio echeck by 3 times theNOx level the amount allowed is 607 and I'm getting 1774 this sucks! Can anyone help? I can't drive until I pass this. I am gonna try to get it to a garage but am out of ideas.
Old May 6, 2011 | 11:31 PM
Dayta's Avatar
put the stock header and dp back on, pass, take it off
Old May 6, 2011 | 11:41 PM
ssblacksc's Avatar
I agree with u there but I don't have either of the stock exhaust parts. Anyone in the area have the stuff laying around? I'll buy a case of beer and then return it or anyone have one for cheap?
Old May 7, 2011 | 01:18 PM
blitzed~beretta's Avatar
your running your engine too hot. high combustion temps = nox. what tune are you running? you really shouldn't even need a cat to pass nox, you shouldnt be making any in the first place.
Old May 7, 2011 | 02:09 PM
ssblacksc's Avatar
I just got a pcm from zzp that has a canned tune on it. I don't know about anything else but I am failing by triple the allotted level. How do you cool the engine down to pass?
Old May 7, 2011 | 03:07 PM
kitchener ss's Avatar
Not sure if this will help but, I just ran into the same problem,not a week a go. Here in Ontario our limit is 505 NOx, my car ran a 996 NOx. I took the car to my mechanic, checked over the whole car and found my o2 sensor was not working all of the time. I had the o2 replaced and put my factory air box back in and filled up with 94 octane. I took it back for a re-test and my NOx read zero.
My mods are GM stage 2, option B with added front mount HE, J-Body, even length header with GM sport tuned exhaust and factory cat.
I hope this helps.
Old May 7, 2011 | 03:13 PM
ssblacksc's Avatar
That sounds about right, I bet my o2 sensors are not working properly then. I will take a look and possibly change them out. Heck why not both of them.
Old May 7, 2011 | 03:17 PM
red06s/c's Avatar
i have 60's,2.7,header,down pipe, exhaust and mine just passed the first time. The dude who tunes mine shut the rear o2 off on my car. think maybe if u run the a/c the fans will kick on and keep it cooler?
Old May 7, 2011 | 03:28 PM
It was just my rear o2 that I had a problem with... Good luck!
Old May 7, 2011 | 04:18 PM
ssblacksc's Avatar
Red my problem was that they are making me pass the sniffer test not the odb2 reading. I had no history on my car and they said to pass they would have to do the sniffer test. I failed so now I have to pass the sniffer test before I can use the computer reading again. I am gonna try the u2 sensor because I know mine looks a little rough
Old May 8, 2011 | 08:00 AM
red06s/c's Avatar
ah i see. mine did the scanner one
Old May 8, 2011 | 08:03 AM
05Slowline's Avatar
prob too rich which a canned tune should be
Old May 8, 2011 | 10:49 AM
OntarioKev's Avatar
You can get a car to pass emissions by using HP tuners to drop the advance to about 18 degrees total timing in the area the of the map where the crusing emissions is run. I got someone to pass who had over 2k NOX down to 500 by doing this.
Kevin
Old May 8, 2011 | 10:53 AM
BLAZIN07SS's Avatar
I'm too JDM for you
rich would cause the hydrocarbons to be too high. lean causes NOx to go up.
Old May 8, 2011 | 10:58 AM
05Slowline's Avatar
oh lol fk if i know i just take it and they look for a cat shell and 420 code haha
Old May 13, 2011 | 12:09 AM
ssblacksc's Avatar
I will give this a try. I know a guy in Youngstown area that has HP maybe he can help me out. If not does anyone in the Akron area have Hpt to help a brother pass an emission test. I hate echeck, I went to the big shot dyno day and no one there even has to pass it. What a jip this is pure BS!
Thanks Kev I'll give it a try.
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
Extremespeed
Sep 29, 2015 04:34 AM
Slick_Nick
Sep 28, 2015 09:15 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
