high temps!
Old Feb 4, 2008 | 07:04 PM
brownbandit9's Avatar
high temps!
i installed my cobra heat exchanger yesterday and today while in drive through the guage under my tackometer climed from 180 to 216 degrees.. i know im not movin so air is not passing through but i dont ever remember my stock setup going that high at idle...also that guage is reading the coolant that runs through my h/e and manifold right...?
Old Feb 4, 2008 | 07:11 PM
D4u2s0t's Avatar
that's pretty normal. nothing to worry about. probably dropped right back down after you started driving again.
Old Feb 4, 2008 | 07:14 PM
an0malous's Avatar
the gauge under your tach has nothing to do with your cobra HE
they are completely different cooling systems.
Old Feb 4, 2008 | 07:20 PM
thats is what i was thinking...i need to get aerforce guage to scan those iats correct ? is that the only way..and which coolant is that reading cus it did drop instantly when i started driving so i thought it was the h/e..thanks
ohh and ill try and post pics of the install. i went a little bit different rout then the other wright ups
Old Feb 4, 2008 | 07:21 PM
an0malous's Avatar
thats reading your engine coolant.
you already have a radiator for it, so naturally it will cool once you start driving.
the Aeroforce interceptor is a great way to read your IAT2 temperatures yes.
no_ss
Oct 18, 2015 11:58 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Slick_Nick
Sep 28, 2015 09:15 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
