high wing removal
Old Aug 6, 2007 | 04:54 PM
cobaltstg2's Avatar
high wing removal
how the hell does that thing come off.... like i said i have the high wing and i want to take it off and go wingless... i unbolted the 4 bolts holding the thing on but there is some kind of tape holding it on .. what is the best way to get it off without scratching the hell out of my paint
Old Aug 6, 2007 | 04:56 PM
SKDR112888's Avatar
double side tape its strong too get like a heat gun and it will come loose
OrngBalt's Avatar
Hair dryer and fishing line... just like the badges
Old Aug 6, 2007 | 04:57 PM
cobaltstg2's Avatar
^^^^ tried that one didnt work kept breaking the fishing line
Old Aug 6, 2007 | 04:59 PM
OrngBalt's Avatar
Ive used bug and tar remover to help dissolve, hair dryer to heat it up and 20lbs test line. broke a line once but thats cuz i didnt let the remover sit long enough and didn't heat it enough.
If you have to, see if you can get your hands on some stronger fishing line
Old Aug 6, 2007 | 05:02 PM
cobaltstg2's Avatar
yes i will try that... 20lbs test thank you
Old Aug 6, 2007 | 05:41 PM
Johnboy12358's Avatar
Get a real heat gun, it will come off easy. Hair drier isnt hot enough.
you might want to get a friend to help out, heat it up and try and pull at the same time. I just swapped my spoiler this weekend, and doing it that was was the easiest (thats how we got the low rise one off the other guy's car)
I used a hair drier to get the big one off my car and that was a huge PAIN
Old Aug 6, 2007 | 05:47 PM
RedCobaltSS06's Avatar
I used a heat gun to switch from low pro to high pro. It took about 10 minutes plus bolting it back on. wow.
Old Aug 6, 2007 | 05:49 PM
BallsoutBalt's Avatar
I pryed mine up and got a Hacksazw blade and cut the tape as it streched. Then used Goo-Gone to get the remaining tape off. Just be careful not to dent your trunk when you are prying on it =(
Old Aug 6, 2007 | 05:59 PM
SCcobaltSS's Avatar
Yah Chris has like 10 little dents all over. And his now looks like a lady bug from how he covered up the wholes. lol. Word of advice, dont pry it off.
Old Aug 6, 2007 | 06:00 PM
Old Aug 6, 2007 | 06:04 PM
SCcobaltSS's Avatar
Im only kidding buddy. I get to make fun of you on both site. Its the high-light of my day.
Old Aug 6, 2007 | 06:07 PM
gashousecobalt's Avatar
just find someone local im sure someone with no wing wants the high mount wing so just get with them and do a trunk swap thats what i did, it will save you time and money saved me 500 bucks and saved the other guy 300
Old Aug 6, 2007 | 07:30 PM
cobaltstg2's Avatar
i want to keep my wing.. i just want to see what it looks like with it off.... plus i want to be able to take it off for the track
Old Aug 6, 2007 | 07:37 PM
DarkCobalt13's Avatar
I just used a field knife and some elbow grease. Did it on my own, nothing broken or damaged. Lift up in th wing and cut away at the adhesive till it gives away, then move to the other side.
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
Cptnslo
Sep 24, 2015 09:32 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
