horrible month
Old Feb 14, 2011 | 06:04 PM
startingline05's Avatar
horrible month
my car has went through alot this month. anywhere from skipping timing to boost leaks. i have went through everything i could think of and cant figure out why im not hitting 25psi like i should and have done before. can anyone just throw out some suggestions for me and why you would lose boost. my normal is 25psi and im hitting around 20psi. recently my timing has been reset and i added a return fuel system, but this has been going on before all that.
Old Feb 14, 2011 | 06:06 PM
jonnymerk's Avatar
Wastegate failing? Are you turbo? I didn't think the SC's boosted that high
Old Feb 14, 2011 | 06:13 PM
Tarheel62592's Avatar
lol what are your mods? what kinda car do you have?
Old Feb 14, 2011 | 06:17 PM
super06sport's Avatar
more info more info more info
Old Feb 14, 2011 | 06:23 PM
troyss's Avatar
Of course it's Turbo if he's boosting 25psi
Old Feb 14, 2011 | 06:56 PM
alleycat58's Avatar
Could be TVS....jussayin
Boost leak? Bad BPV?
What have you checked and/or eliminated as potential problems?
Last edited by alleycat58; Feb 14, 2011 at 06:56 PM. Reason: Automerged Doublepost
Old Feb 14, 2011 | 08:47 PM
sorry i should have explained alittle more. i have a tvs set up. when i first installed it i was hitting 25psi. after i took it off again to replace some house for my endplate is when i started having the boost leak. after first the needle was being alittle shaky at about 22 to 23psi no its just hitting 20 psi. i replaced all the gaskets besides the one between the s/c and the manifold which i do have (just havent replaced it yet) but i dont think the gasket could be the reason y i would lose 5 psi. also i just added the return fuel system, but that wouldnt cause it to lose boost. i dont think :/
Supercharged06SS
Dec 11, 2022 04:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Trav3480
Oct 1, 2015 08:17 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
