how big is this exhaust?
yeah your not to far away. hey what do you think about running 3'' all the way back? cuase i already have a 3'' dp and CA header. or should i just get a 2.5'' cat back?
run 3" dude it will be fine but dont buy an exhaust just go to a local exhaust shop and have them make you a custom catback all you need to do is buy the muffler(magnaflow) and your set..will save you like 350-400 bucks
so then a 3'' dp with a 2.5 out the back?
well if i go with the gmpp where do i go to get a decent tip?
Last edited by 07cobaltss; Feb 25, 2007 at 09:10 PM. Reason: Automerged Doublepost
ok well i already have the 3'' dp with high flow cat. and this chart isnt just for the LSJ motor. this is an overall chart. some vehicals dont need a whole lot of back pressure because they are not EGR.
its a better idea of what to expect though. if your ready to spend some dough a 3" would be a good way to spend a good chuck of change
so then i should just get the gmpp and use the 3'' dp? if i do that where do i get a good tip?
but the vibrant cat back is cheaper than the magnaflow and the vibrant is a 3''? so would i see a positive gain, or would i be lossing power... any gain over stock is good, i jsut dont want to lose anything.
so i guess what i'm asking is here is two things i can do. i can get the vibrant cat back and go 3'' from header dp back, or i can run a 3'' dp and go to a 2.5'' cat back.
Last edited by 07cobaltss; Feb 25, 2007 at 09:20 PM. Reason: Automerged Doublepost
ok but what should i do? the 3'' all the way back. or the 3'' dp to the 2.5'' cat back? either one i can do, if i go 3'' it will be vibrant, if i go 2.5 it will be gmpp.
the gmpp is not 2.5 its 2.25. your choice should be based on where you will eventually be as your go on and keep modding. if you do a sc'er swap maybe a 3 would be good just to mate up to the 3" dp
ok so i'm going to go with the gmpp 2.25'' cat back and mate it up to the 3'' dp, shouldnt be to big of a problem, the 3'' can mate with 2.25''. and my back pressure shouldnt be a problem right, since i'm bringing the 3'' down to a 2.25?
it should work fine when you get off the gas I can just imagine how the exhaust note will be very throaty im guessin
i'm cool with that =)
hey onimirage thanks alot for all your help!!! i really appreciate it!
Last edited by 07cobaltss; Feb 25, 2007 at 09:35 PM. Reason: Automerged Doublepost
