how to check if boost soleniod doesnt work
Old Feb 29, 2012 | 04:01 PM
tanelk's Avatar
How do u check if the bypass valve and boost soleniod doesn't work anymore
Old Feb 29, 2012 | 04:17 PM
tanelk's Avatar
Old Feb 29, 2012 | 04:53 PM
tanelk's Avatar
Old Feb 29, 2012 | 04:54 PM
sick CCSS's Avatar
had problems with mine the other day, too kthe 2 boltso ut, lubed the rod and got it to work free again.
Old Feb 29, 2012 | 04:57 PM
tanelk's Avatar
Lubed the what rod?
Old Feb 29, 2012 | 11:55 PM
sick CCSS's Avatar
im talking about the black by pass actuator valve on the s/c, sometimes the rod can get coroded and cause it to stick in spots, mine was. i was also running meth at the TB, still am, just gotta keep an eye on it.
Old Mar 1, 2012 | 12:03 AM
chris88z24's Avatar
have somebody rev the car while watching to see if the rod moves
Old Mar 2, 2012 | 04:58 PM
tanelk's Avatar
The rod moves only a little
Old Mar 2, 2012 | 06:24 PM
sick CCSS's Avatar
at an idle the valve isnt gonna move a whole lot since its not gonna build much boost, just pull the lever and feel for any rough spots.
Old Mar 2, 2012 | 07:06 PM
tanelk's Avatar
The rod is a little rusted, I'm just going to get a new actuator and soleniod
Old Mar 2, 2012 | 07:41 PM
nhanson's Avatar
Lube your rod.
Old Mar 2, 2012 | 08:05 PM
mrbelvedere's Avatar
the boost bypass solenoid is depowered open so if you unplug it the solenoid will open and not allow the car to go into boost
Old Mar 2, 2012 | 09:39 PM
Powell Race Parts's Avatar
If you have been running meth pre blower for a while, in my experience, your bypass valve cross shaft is probably corroded and sticking and the valve cant move it. try some penetrating oil, it may help but the only permanent solution is to remove the blower and fix it right.
Turbo Johnny
Feb 21, 2019 09:41 AM
TurboTechRacing
Oct 27, 2015 07:58 AM
Cptnslo
Sep 24, 2015 09:32 AM
Fearedbynone
Sep 4, 2015 10:24 AM
