How does this set-up look?
Old Apr 25, 2008 | 03:37 PM
Perfect.disguise's Avatar
The only mod I have is the air box mod.I plan on adding in this order...
1. Cx Heat exchanger
2. Intense stage 4 (with Stage 2 belt)
LSJ-MSS-625 - Machined Gen V M62 Supercharger Snout
LSJ-INT-SCO - INTENSE™ Supercharger Oil (8oz)
GVC-GMT - GM Gasket Maker
LSJ-IMH-090 - INTENSE™ LSJ Modular Pulley System
LSJ-IMP-270 - INTENSE™ 2.70" pulley
LSJ-STP-630 - Oversized Supercharger Tensioner Pulley
LSJ-ASP-3922 - Autolite® Copper Core Spark Plugs
LSJ-FIS-600-4 - Siemens 60 pound/hour Fuel Injectors
LSJ-CIH-102155 - Casper's LSJ Injector Wiring Harness
INTENSE™ Stage 4 LSJ PCM
3.Then work on full exhaust
4.Dyno tune
Does that sound like a good set-up?
Old Apr 25, 2008 | 03:39 PM
Rangerondubz's Avatar
I would add some gauge's such as a Wideband & Pyro in there before the S4 Kit
DoubleLP's Avatar
If you go Stage 4, you are going to want to get a tune ASAP so not to destroy anything.
Old Apr 25, 2008 | 03:40 PM
Canned tunes can mean disaster, just make sure you can monitor everything.
Old Apr 25, 2008 | 03:56 PM
Area47's Avatar
Rent me! per hour
whats the gasket maker for?
Old Apr 25, 2008 | 04:49 PM
It comes with the kit prob for the S/C-Intake Manifold mating but you dont need it, well if you did I didnt use it
Old Apr 25, 2008 | 04:54 PM
ifknrock09's Avatar
looks fine but are you doing the tunning or is intense? i here that intense tunes are ****. but then again i don't have and intense tune. just a few friends that do and all of them have something wrong with their ****.
Old Apr 25, 2008 | 05:01 PM
Omega_5's Avatar
Putting the SC back together....
They sent out a machined snout, and you have to send in the old one as a core.
At the OP; that kit is fine and dandy, but see if you can; get a 2.8 instead. It's a bit safer, and you don't have to machine the snout or anything.
Old Apr 25, 2008 | 05:56 PM
Area47's Avatar
Rent me! per hour
it's called high temp silicone. or honda bond. lightly applied. none of the paper "whoopsies" gasket crap.
Old Apr 26, 2008 | 05:40 PM
Would the CA stage 4 be any better? Stage #4 : 2.6 ZZP Interchangeable Pulley system , 2 step colder ngk IRIDIUM spark plugs , GM shortened belt , ZZP Adjustable Tensioner , 60# Siemens Injectors , Injector Wiring Harness, Stage #4 Retune. I can't really decide what to do. Are our cars bad enough to really worry about the warrenty?I was also considering GM stage 2 with a 2.9 ..my local chevy shop told me install would be 2.5 hrs and $172.50. What would be a ballpark figure for gains on that?Later on if I had GM stage 2 if I wanted a smaller pulley and 60's would I have to get a new tune?
Old Apr 26, 2008 | 05:41 PM
Dayta's Avatar
meth/alcohol injection
Old Apr 26, 2008 | 05:51 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Dual Pass Option B
Old Apr 26, 2008 | 07:32 PM
Johnny B's Avatar
i agree with ^^^
Old Apr 26, 2008 | 07:38 PM
SSRedSC's Avatar
The install time is not a bad price, but its a waste of money if your going to get a smaller pulley and 60lb injectors. Neither of which come with it and the tune wont work so...
and intense canned tunes are **** from what gets said on here.
Old Apr 26, 2008 | 07:42 PM
Dayta's Avatar
dont do a stage kit
get 60s, 2.8 and a custom tune
Old Apr 26, 2008 | 07:52 PM
Any word on the Cobalt Addiction tunes? ... I wouldn't figure all canned tunes could be so bad considering thats what the GM stage 2 is. I would only need the tune until I get full exhaust afterwards and then have it dyno tuned. Not that it really matters but I also only drive this car on the weekends.
Also where would be a good place to look for tunning shops in VA?
Last edited by Perfect.disguise; Apr 26, 2008 at 07:52 PM. Reason: Automerged Doublepost
Old Apr 27, 2008 | 12:13 AM
Maxim_X's Avatar
If your going to get tuned then there is no point in getting a stage kit. Do a 2.6, small belt, meth, a custom tune and full exhaust will get you where you want to be,
Old Apr 27, 2008 | 08:35 AM
Dayta's Avatar
i think a 2.6 is too small and can over spin the sc
2.7 is a good pulley with the meth, and will give you plenty of boost
Old Apr 27, 2008 | 10:53 AM
If I do my own kit I would have to get it tuned before I drive my car AT ALL after adding the pulley and 60's? If so would I have to get it tuned after exhaust and whatnot again?
Old Apr 27, 2008 | 06:16 PM
Shermen's Avatar
I love how every one says intense tunes are ****. I love my intense tune. I have never had any problem with it.
Old Apr 27, 2008 | 06:20 PM
RA071623's Avatar
Hmm I would stay away from Intense stage kits.
Badmunky
Mar 16, 2015 12:13 PM
averagewhiteboy
Dec 20, 2007 01:58 PM
qwkeco
Stuff
Nov 7, 2007 07:45 AM
Nyke
Nov 6, 2007 11:47 PM
Coblt ss super
Oct 29, 2007 03:53 PM
