How does it work
Old Feb 16, 2012 | 04:04 PM
stock2.0ss's Avatar
How does it work
How does the wot box work
Old Feb 16, 2012 | 09:40 PM
Proinmaster's Avatar
Im pretty sure it is wired into the ignition. When hit wot ( wide open throttle) it is activated. cutting out the ignition for a few seconds to give you time to no lift shift. Also with the clutch in, if you go wot quickly it cut out the ignition for launch control while your at idle. I have it in my 07 ss/sc and it works great. You can change the revs you want it set at while activated as well as your boost level for launch control. I believe thats about it.
Old Feb 16, 2012 | 10:20 PM
sick CCSS's Avatar
do you have to cut and splice any factory wires for this?
Old Feb 16, 2012 | 10:33 PM
TStone's Avatar
Normally you have to tap into your ignition wire....
Old Feb 17, 2012 | 12:01 AM
sick CCSS's Avatar
ok, i really want the WOT box, but i hate messing with factory wirering casue sometimes it causes head aches down the road.
Old Feb 17, 2012 | 12:07 AM
nhanson's Avatar
Pretty sure the WOT box is all wiring. Wire to the ECM and ignition
Old Feb 17, 2012 | 12:08 AM
paintballerr78's Avatar
its easy to install as long as you follow the instructions on the site
Old Feb 17, 2012 | 02:39 PM
06cobalt racer's Avatar
you splice into about or 6 wires
Old Feb 17, 2012 | 02:46 PM
Pyros777's Avatar
This should help:
cobaltssinstallationinstructions - www2
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
jmelton327
Sep 26, 2015 10:04 PM
