How to eliminate Check engine light
I have an intense stage 3 tune with a K&N CAI, how can i get my check engine light to turn off. I know you can shut it off with hptuners but you still wont pass emissions. I'm talking about correcting the A/F so that it will shut off on its own.
Couldn't tell you, I got the dealer cel-be-gone reflash, but I don't think that do-able since you have the intense set-up. :nono: Should have gone with GM stage 2!
sucks you live in a state that checks for emissions. Good luck getting to pass. I don't have to worry about that in MI :)
You can still pass emissions with turning off the code your throwing threw hp tuners, or you could get a scan tool, just figure out the code first and go from there.
i found a way i think to completely eliminate it ad pass inspections...ther eis a way to completely disable the MIL from the pcm
nice maybe you can do it for me, that would be awesome
WARNING... Tampering with emissions control devices can be illegal. Please check your local laws as well as EPA rules and regulations for legal modification. Disabling emissions controls should be used on off road use only vehicles. It is illegal to modify diagnostic test results in order to pass emissions testing. FOR OFF ROAD USE ONLY.... Ok..... that said and done.... for anyone looking to AUTOCROSS or make it OFF ROAD... HERE IS WHAT YOU DO.... you can remove whatever code you want.... Lets say you always get the P0171 code. You remove P0171 Fuel Trim System Lean Bank 1 from the DTC's by removing the (Check mark) on the SES Enable and set Error Mode = 3-No Error Reported Let's say you elliminate secondary o2 sensor completely along with catalitic converter on the car. Install a ZZP OFF ROAD PIPE... Here is what to do ... Under the Engine Diagnostics table in HPtuners... General tab You'll see Diagnostic Tests P0101,P0106,P0121 Min ECT=131 Max ECT=257 P068 Enable RPM=800 So these tests never run set the following so they are out of range of normal driving conditions... Set Min ECT=280 P0068 Enable Rpm= 8000 In the DTC's tab Remove the (Check mark) on the SES Enable and set Error Mode = 3-No Error Reported P0036 HO2S Heated Control Circuit Bank 1 Sensor 2 P0136 HO2S Circuit Bank 1 Sensor 2 P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2 P0138 HO2S Circuit High Voltage Bank 1 Sensor 2 P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2 P0141 HO2S Heater Performance Bank 1 Sensor 2 P0420 Catalyst System Low Efficiency As far as the tests go... car completes them without having the cat or 2nd o2 installed. Here is a log of the HP DTC data: No DTC's Detected Continuous Tests Misfire: Complete Fuel system: Complete Comprehensive Component: Complete One per Trip Tests Catalyst: Complete Heated Catalyst: n/a Evaporative System: Incomplete Secondary Air System: n/a A/C System Refrigerant: n/a Oxygen Sensor: Complete Oxygen Sensor Heater: Complete EGR System: n/a Catalyst: complete Heated Catalyst: n/a |
