How long to bleed air from heat exchanger?
Old Aug 18, 2012 | 10:31 PM
08baltls's Avatar
So I'm posting this here instead of the 2.2 forum cause it pertains more to the LSJ s/c system.
I installed a full supercharger kit a couple weeks ago and last week finally got it running. Being a pieced together kit everything was bone dry. I filled the cooling system through the filler neck until it stopped taking coolant. I don't have option b yet. So for the last week and a half I've been driving a little bit and refilling when I get home. I don't drive the car every day so I haven't been refilling it every day and when I do it's only a little bit at a time cause that's all it seems to hold through the filler neck.
I'm not getting any symptoms of a blown head gasket or anything like that. No white smoke. No sweet exhaust smell. It just seems to be taking a really long time to get it fully bled. I know the pump works cause I can see coolant flowing in the bottom of the filler neck but it's just not staying full. I also have an AFCO front mount heat exchanger of that helps.
So how long should it take to bleed all the air out? Do I need to do it with the car running or not? Just new to the system and looking for some advice.
Old Aug 18, 2012 | 10:33 PM
Powell Race Parts's Avatar
the stock T bottle is a pita to bleed air out of. Make sure all is plumbed correctly and the sooner you go to option B the happier you will be.
Old Aug 18, 2012 | 10:34 PM
Twoozofjuice's Avatar
Filled mine that same day shouldnt take that long..mine will start to come out of the tube if i open it so i guess that means its full..
Old Aug 18, 2012 | 10:51 PM
08baltls's Avatar
Everything is plumbed properly, it's just not all the OEM formed hoses so some may be longer then what they came with from the factory. In fact I k ow the heat exchanger hoses are because they run from the driver side of the manifold to the heat exchanger nipples on the passenger side.
It seems I'm just adding fluid about a filler neck or two at a time. I've got about 1/2 gallon of dexcool, about 1/4 bottle of water wetter, and about 1/3 gallon of water. I know it takes quite a bit of coolant to fill it completely. Maybe I'm just being paranoid. Haha
Old Aug 18, 2012 | 10:54 PM
zrated89's Avatar
the intercooler system coolant is seperate from you engine coolant. So you wouldnt see symptoms of a blown head gasket or coolant smell. unless an o ring on a laminova tube is leaking but thats highly unlikely
Old Aug 18, 2012 | 11:00 PM
08baltls's Avatar
It happened. When I bought the intake the guy had swapped 4 of the stock o-rings for something from autozone and when I tried filling it, it leaked coolant into the intake. However that problem was fixed. The blown head gasket symptoms thing was the only way I really knew how to describe coolant going through the combustion chambers.
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
