How much can the Head handle?
wow someones rich
If I had the money (which I don't) I would merge 2 LSJ motors into a 4 liter V8. The heads are some of the most efficient heads I've ever seen. Then I'd DUAL twin screw SC it!!!
This is something ive wondered as well, ive looked at a HP tuners file from a stock 06 SS and it looks like you can tune fuel and spark right up to 8192RPM which is the limit in HP tuners, I run 7000rpm currently on a 2002 Supercharged Ecotec Cavalier (stock redline is 6500) with no issues at all, gm runs 7000 on thier stage 2 cobalt kits so its safe to say it should be ok till 7500 possibly more, I would think the LSJ head is better and has stronger valves than a regular L61
Originally Posted by Blown 4-banger
wow someones rich
Edit: But then you'd need a fully custom trans, axles, you would have to wire up the gas pedal to power both engines, feed some lines of gas from the gas tank to the rear engine, etc. It's possible though....at least I think it would be, if money weren't an issue lol
Is it even possible to have two engines turning both front wheels? ..... well if you had enough money to put two engines in, might as well make it rear wheel drive
i dont know if anyone makes valve springs yet but i would have to suggest replacing them for a 500hp build being that they will float the valves @8k (according to gm in a class i recently took.) of course this is on stock cams i have no idea at what rpm you would experience valve float on jpb stage 3 cams. but if you have 2 heads why dont you find out for us
course the second head wont help your valves or pistons much
Originally Posted by Malaclypse
ARP Headstuds. MLS or copper head gaskets. Possibly O-ring the block.
Enough said.
Enough said.
We carry the complete Ferrea Racing valve train for the Ecotec. Dual springs, Spring steps, Titanium retainers, race valves, and to benifit Comp Cams.
There is a lot of old ground being covered here. I have moved this out of the Advanced section.
Separately, the head itself is in fact the least of your concerns in a 500 HP build. The information concerning a new gasket and studs is correct. However, you will need to pay more attention to your rotating assembly then you do the head. You will need new rods and pistons. Not even the LSJ's forged internals were meant for anything more then 300 HP.
Sep 28, 2015 12:51 PM
