Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   how often should trans fluid be changed? (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/how-often-should-trans-fluid-changed-155730/)
Jkunzy1690 Feb 14, 2009 08:31 PM
jw....i have 48k..and what kind is best ?
MP Cobalt Feb 14, 2009 08:33 PM
trans fluid should be good for like 100k i beileve
Jkunzy1690 Feb 14, 2009 08:34 PM
thats what i figured...
BLAZIN07SS Feb 14, 2009 08:51 PM
i would recommend changing it around 50k, gm recommends the fluid be changed at 50k for sever service and we all know how we drive our cars. lol
Jkunzy1690 Feb 14, 2009 08:54 PM
lol good call. and should i change it with the saturn trans fluid or gm? or its prolly the same huh
ViSiONZ Feb 14, 2009 08:56 PM
Why not try reading the drivers manual that came with the car? There's lots of useful information in there.
Jkunzy1690 Feb 14, 2009 08:57 PM
haha thanks for that. o and ill make sure i change my oil every 5 thousand miles as well:lol:
ViSiONZ Feb 14, 2009 08:59 PM
LOL, why not? Some people wait till the last 5% on the oil life meter & have no problems.
Jkunzy1690 Feb 14, 2009 09:00 PM
lol they can take their chances- i will NOT! lol
Jn2 Feb 14, 2009 09:05 PM
Just fond out the weight of the tranny oil and use mobil1 tranny fluid
BLAZIN07SS Feb 14, 2009 09:07 PM
use OEM, you cant go wrong
GM part #88862472
Jkunzy1690 Feb 14, 2009 09:11 PM
sp should i use mobil 1 or oem?? lol opinions please
BLAZIN07SS Feb 14, 2009 09:13 PM
anything less that a 75w90 and GL4/GL5 approved fluid will screw this tranny up. requires 2 quarts BONE DRY so it should only need about 1.75 quarts
qwikredline Feb 14, 2009 09:21 PM
OEM ..................
flobeelicious Feb 14, 2009 09:29 PM
just did this on mine. as usual, the car isn't really designed for ease of maintenance.
I used the gm fluid - i would be shocked if the 75 w 90 was the same weight - the stock stuff was much thinner than i expected. you may need to cut down a 8 mm allen wrench as well, not a lot of room to play.
as far as fill quantity, expect to use damn near the full 2 qts. official capacity is listed as 1.9 qts, and thats just about when it started to dribble out of the upper fill hole. (filling to this point is the recommended procedure)
on a side note, the service manual also recommends using a sealant on the drain plugs - didn't notice that part until i had mine refilled.
Dainslaif Feb 14, 2009 10:09 PM
GM stuff is the same price as Mobil 1, there's no reason to buy other stuff unless your local dealer was trying to charge $20/qt like mine was.
rukkee Feb 14, 2009 10:17 PM
OEM , i did mine cause i wanted to be safe . I used 2 quarts of the saturn oil and had just a little left over . It's hard to get all the old oil out . My tranny was noisy since new , and changing the oil quieted it down a bit .
SSPainter Feb 14, 2009 10:26 PM
i switched to royal purple at 40k took about 15min tops. Very easy
Johnboy12358 Feb 14, 2009 10:46 PM
Royal Purple sychromax or max gear 75w90?
Dainslaif Feb 15, 2009 02:01 AM
Just use the GM stuff. There's no reason to buy the more expensive oil that doesn't do anything special.
wtpcobaltss Feb 15, 2009 02:24 AM
oem...they wouldnt put the stuff in the car for no reason. i will always use oem oil,fluids. Most of the other crap is seriously just bait to make u wanna pay more for the same qualty.by miss leading titles of improved hp and fuel economy
