how often should trans fluid be changed?
Old Feb 14, 2009 | 08:31 PM
Jkunzy1690's Avatar
jw....i have 48k..and what kind is best ?
Old Feb 14, 2009 | 08:33 PM
MP Cobalt's Avatar
trans fluid should be good for like 100k i beileve
Old Feb 14, 2009 | 08:34 PM
Jkunzy1690's Avatar
thats what i figured...
Old Feb 14, 2009 | 08:51 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i would recommend changing it around 50k, gm recommends the fluid be changed at 50k for sever service and we all know how we drive our cars. lol
Old Feb 14, 2009 | 08:54 PM
Jkunzy1690's Avatar
lol good call. and should i change it with the saturn trans fluid or gm? or its prolly the same huh
Old Feb 14, 2009 | 08:56 PM
ViSiONZ's Avatar
Why not try reading the drivers manual that came with the car? There's lots of useful information in there.
Old Feb 14, 2009 | 08:57 PM
Jkunzy1690's Avatar
haha thanks for that. o and ill make sure i change my oil every 5 thousand miles as well
Old Feb 14, 2009 | 08:59 PM
ViSiONZ's Avatar
LOL, why not? Some people wait till the last 5% on the oil life meter & have no problems.
Old Feb 14, 2009 | 09:00 PM
Jkunzy1690's Avatar
lol they can take their chances- i will NOT! lol
Old Feb 14, 2009 | 09:05 PM
Jn2's Avatar
Jn2
Just fond out the weight of the tranny oil and use mobil1 tranny fluid
Old Feb 14, 2009 | 09:07 PM
BLAZIN07SS's Avatar
I'm too JDM for you
use OEM, you cant go wrong
GM part #88862472
Old Feb 14, 2009 | 09:11 PM
Jkunzy1690's Avatar
sp should i use mobil 1 or oem?? lol opinions please
Old Feb 14, 2009 | 09:13 PM
BLAZIN07SS's Avatar
I'm too JDM for you
anything less that a 75w90 and GL4/GL5 approved fluid will screw this tranny up. requires 2 quarts BONE DRY so it should only need about 1.75 quarts
Old Feb 14, 2009 | 09:21 PM
qwikredline's Avatar
OEM ..................
Old Feb 14, 2009 | 09:29 PM
flobeelicious's Avatar
just did this on mine. as usual, the car isn't really designed for ease of maintenance.
I used the gm fluid - i would be shocked if the 75 w 90 was the same weight - the stock stuff was much thinner than i expected. you may need to cut down a 8 mm allen wrench as well, not a lot of room to play.
as far as fill quantity, expect to use damn near the full 2 qts. official capacity is listed as 1.9 qts, and thats just about when it started to dribble out of the upper fill hole. (filling to this point is the recommended procedure)
on a side note, the service manual also recommends using a sealant on the drain plugs - didn't notice that part until i had mine refilled.
Old Feb 14, 2009 | 10:09 PM
Dainslaif's Avatar
GM stuff is the same price as Mobil 1, there's no reason to buy other stuff unless your local dealer was trying to charge $20/qt like mine was.
Old Feb 14, 2009 | 10:17 PM
rukkee's Avatar
OEM , i did mine cause i wanted to be safe . I used 2 quarts of the saturn oil and had just a little left over . It's hard to get all the old oil out . My tranny was noisy since new , and changing the oil quieted it down a bit .
Old Feb 14, 2009 | 10:26 PM
SSPainter's Avatar
i switched to royal purple at 40k took about 15min tops. Very easy
Old Feb 14, 2009 | 10:46 PM
Johnboy12358's Avatar
Royal Purple sychromax or max gear 75w90?
Old Feb 15, 2009 | 02:01 AM
Dainslaif's Avatar
Just use the GM stuff. There's no reason to buy the more expensive oil that doesn't do anything special.
Old Feb 15, 2009 | 02:24 AM
wtpcobaltss's Avatar
oem...they wouldnt put the stuff in the car for no reason. i will always use oem oil,fluids. Most of the other crap is seriously just bait to make u wanna pay more for the same qualty.by miss leading titles of improved hp and fuel economy
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
importkiller
Sep 30, 2015 07:18 PM
Sep 27, 2015 08:53 PM
