how a stock endpalte and dual pass endplate work
Old Apr 11, 2010 | 09:16 PM
scotch89's Avatar
so i did this for a guy that was wondering how these things worked. i just thought i might as well post this and have it for people to take a look at. if you see or read something that dosent sound right please say so thanks.
so as you know the stock endplate makes 4 passes threw the intake manifold.starts from the bottom and zig zags up to the top and drops into your filler neck wich then drops to your heat exchanger to be re cooled. so what a dual pass endplate does is make it so it goes threw your intake maniflod twice instead of four times, making cooler air temps. how the end plate is designed stock is, the first entrance is sealed off so it cant go anywhere but threw the intake manifold A.K.A laminova's. then once it goes threw the intake manifold it then goes into the second part of the endplate. and the 2nd spot is not sealed so its like the 2 middle spots are combined together so there no walls. then they go threw the third one and get sent to the 4th hole wich is sealed with a wall to separate the hot coolant from the mild coolant. now since i covered the stock endplate lets go into the dual pass endplat. now the diffrence between these are,there's a extra hole for the coolant. the extra one is for the coolest coolant to first go threw the endplate. so from the pump it goes to the extra hole on the endplate. then how the duall passs works is by the number 2, and 3 hole that are not sealed with a wall that are combined. the coolant enters the 2, and 3 hole ( by the way you have to swap the lamovas to have the #2 and #3 going in and the *#1 and # 4 going out) going into the intake manifold then the #2 going out of #1 then the #3 going out of #4. then the coolant comes out of #1 and #4 wich then go into a custom tee and goto the filler neck to get shot into the Heat exchanger to be cooled. here the diagram i made from paint
Old Apr 11, 2010 | 09:27 PM
blackbolt89's Avatar
lol at the mspaint but thats a pretty good diagram.
i dont have time to read the article though. lol sorry
Old Apr 11, 2010 | 09:32 PM
YzRider452's Avatar
Not bad, now do a single pass. lol. Dont forget the IC pump.
Old Apr 11, 2010 | 09:49 PM
scotch89's Avatar
i have no clue on the single pass lol
Old Apr 11, 2010 | 10:13 PM
YzRider452's Avatar
Its all in one side, out the other side of the intake mani.
Old Apr 11, 2010 | 10:25 PM
thedude411's Avatar
how much effort is required when u install a dual pass. im lazzeee and am not feeling like looking at the how to lol
Old Apr 11, 2010 | 10:31 PM
scotch89's Avatar
well if your going to do a custom one it requires some time. but if your buying one not bad.....its really not that bad to do. i think the pain in the ass thing was doing the plumbing. but once u get to the intake manifold on removing it. reomve the alternator to get to the back bolt behind the IM its so much easier.
Old Apr 11, 2010 | 10:33 PM
BumbleBee's Avatar
this makes me more confused than I was lol.
Old Apr 11, 2010 | 10:35 PM
scotch89's Avatar
what are you confused on?
Spanky's Monkey
Mar 7, 2016 06:06 PM
Tdubbs
Oct 13, 2015 02:31 PM
Cptnslo
Sep 24, 2015 09:32 AM
Builttss
Sep 22, 2015 12:42 AM
yellowsupercharged06
Sep 15, 2015 04:38 PM
