hptuners question
i have access to the hptuners software from a friend. ive not used this on my car yet since its still in the shop getting the slave cylinder and rear main seal replaced. i have been learning on the stock cavalier that my friend (owner of the tuning software) has.
i am planning on doing my own "stage 2" set up (ie: ZZP modular pulley and puller, 42 lb injectors and harness, and drive belt) and tuning it with the hptuners for the larger injectors, 7k redline, and boost management
Questions:
1. what parameters are you hpt people using for the fuel management with 42 lb injectors? i am still a n00b with adjusting the PE and VE tables and dont wanna jack up my fuel maps and risk breaking ****.
2. what values are you using for the MAF sensor to keep it happy? i am plagued with the usual p0171 DTC from my intake.
Questions:
LSX RWD S/C conversion
Questions:
Questions:
Originally Posted by victory_red_SS
For a fee fast06SS or Intense will sell you a hptuners log file that will get you really close and show you changes to make.
Originally Posted by g5mike
Is the file you have Rob for the 2.0 though, being I would have to purchase one for the 2.4
Questions:
Questions:
For the injectors you need to just setup the curve on the IFR vs VAC for the new flow rate. The curve is set for 34 right now so I just upped mine about 7 # (yes I know it's actually 8, but 8 is too much) Also your IFR vs VAC might have a fucked up spike in the map, I have removed that, and it's a mystery what it's there for.
Of course I recommend chaning the supercharger tq management to your needs, if you have an 2006 your lucky because you get better tq management than us 05 guys.
You can also add more spark, and edit the PE maps and Piston protect (up to 7k for me so it never comes on ) But have a WB02 if your doing to mess with that.
Just do lots of logging with TPS, MAF, Calculated air flow, LTFT, Inj duty cycle, Pulse wdith, RPM ect ect. Load up on data and just get your LTFT dialed in.
hmm i might try to purchase that log file from fast06SS or intense depending on price. i really dont feel comfortable creating my own tables by myself on this car.
Your right, his is for the 2.0. You would need to talk to Rob or Intense about a 2.4 log file.
If I did this Rob,what type of gains etc.. do you think I will get? thanks
I understand that the Westers tune that another 2.4 owner used got about 20hp and he paid $500. for that.
I am thinking you are asking me, Rod, right?
Sorry I meant Rod,I know what the westers tune does,but im curious as to what the hp tuners would do for the car?
Done properly you should see the same results as the Wester's tune.
Originally Posted by Matty
No kidding. Getting 20 HP from any tune is great.
The 20 that guys are gettin is with intake and catback, so the tune itself is like 5hp,But it changes your rev indicater, shift points and torque management, and more.But with hp tuner can I acheive any of these?
Does the HPT work with the 2.4? If so, tweaks can be made for sure. Make the changes to the exhaust etc first then tune it instead of putting on a part then tuning, then doing something else and having to tweak again. IMO. And more than 5 HP can be found inside the PCM
You are saying with my exsisting mods, I should hp tune it, then put the header/downpipe on and tune again? Thanks matty
Actually, Matty is saying put the mods on first and then tune, so your not tuning twice.
