I give up with the CEL. P0172
Old Jul 22, 2009 | 05:58 PM
*boostinss*'s Avatar
Angry I give up with the CEL. P0172
Hey guys awhile ago i had a problem with the cel coming on everyday. well it turned out all my misfiring was cause my faulty coils. well this P0172 ( system to rich) Bank 1. will not stop. i though it was getting caused by the random misfiring but i guess not. what can this be? Today every time i delete the code it comes back within seconds. and the cel is like a needle in my eye.
Old Jul 22, 2009 | 08:11 PM
harryresh's Avatar
Your gonna have to have a shop check it out. Im having the same problem and im having a local tuner look into it...
Old Jul 22, 2009 | 08:14 PM
BLAZIN07SS's Avatar
I'm too JDM for you
something is causing your LTFT's(long term fuel trim) to pull too much fuel
Old Jul 23, 2009 | 09:19 PM
any other ideas?
Old Jul 24, 2009 | 05:19 PM
joe118969's Avatar
I get this code, and its always while idling somewhere after driving for awhile. At about 1100rpms. I'll post my freeze frame data from my scanner when it happens again for me. I just delete it and go on my way. But I believe it can be 1 of 4 things, and im not one to play a guessing game replacing parts that don't need to be.
My car has a 2.9 pulley, lucas injectors, and a tune from psykosteve.
And it started happening this summer for my car.
Old Jul 24, 2009 | 09:17 PM
yeah thats it idleing and low throttle% never at full throttle. in stock besides a intake and catback.
Old Jul 24, 2009 | 09:25 PM
exninja's Avatar
Have you tried valve lash adjustment? I'm still new to the intricacies of the ecotec, but on my integra i got the same code, as well as the a/c not working well. I did a lash adjustment and fixed both! It only took 20 minutes. Again, not sure if it's that easy on your engine.
Old Jul 24, 2009 | 09:37 PM
eastcoastz's Avatar
How many miles on your car? I've seen O2 sensors in the exhaust manifold cause a false lean code because they were failing. Also you have an 06 with an intake on a factory tune which will cause this unless you have the current update or a stage 2 tune.
Old Jul 24, 2009 | 11:38 PM
i have put new upstream and down stream O2 sensors in my car. and yes im running on a stock tune but i was told by numerous people that the intake would cause a lean code not a rich.
Old Jul 24, 2009 | 11:39 PM
oh sorry i have 34,794 miles on my car i just went outside a checked
Old Jul 25, 2009 | 12:24 AM
scotch89's Avatar
i had this happen to me today. i put a spectre intake on and never disconnected my batterie. so i was in a city and kinda launched my car and i had a check engine light come on. i took it to auto zone they gave me that code. then i disconnected my batterie for about 5 min. put it back in and did a couple of hard pulls and it hasnt came on. what if u cleaned ur maf sensor and TB. i did that two days ago to get my rpms from jumping around. maybe?
Old Jul 25, 2009 | 12:36 AM
my penis is big's Avatar
get smaller injectors or convert to tune port injection off a 86 iroc ill sell you one for 1k or trade for a lb of weed
Old Jul 25, 2009 | 03:21 AM
scotch89's Avatar
^^^^seriously????
Old Jul 25, 2009 | 04:35 AM
2K5SS/SC?'s Avatar
When was the last time you cleaned your MAF?
Old Jul 25, 2009 | 04:41 AM
OneCOLDBIZL272's Avatar
dirty maf or its cause of your intake...get a tune of go back to stock intake
Old Jul 25, 2009 | 11:23 AM
well i cleaned my maf sensor and throttle body 2 days ago and nothing happened same crap. i just found a chassi dyno(dyno jet) in lancaster Its only a hour drive away.maybe they can fix this problems. while im at it i can put my 42lbs injectors on and my 2.9" pulley one and just get it all tuned for that.
Old Jul 25, 2009 | 11:32 AM
yel-low's Avatar
where in lancaster and how much do they charge
Old Jul 25, 2009 | 11:44 AM
redline4's Avatar
Change your plugs and see if that helps.
Old Jul 25, 2009 | 03:56 PM
domin8_gt's Avatar
What size injectors do you have in it now? Not tuning for injectors could cause a problem.
Old Jul 25, 2009 | 09:06 PM
in stock injectors and stock pulley. and im running on a stock to also
Old Aug 2, 2009 | 08:35 PM
chris06ss's Avatar
you said a current update what do you mean reflash ?
Old Aug 4, 2009 | 12:44 PM
hey guys i got some more info for ya! well first ill just tell you guys im still on the stock tune with just an intake and catback. well i noticed somethings about the cel. well i just noticed that it only comes on when i have a 1/4 tank or less of gas? when its full 3/4,1/2 nothing but when it gets low it comes on. today i had a 1/8 of a tank and it kept comeing on right after i deleted it 9 times in a row. so i gave up and fill my tank and it stoped comeing on? i hope this helps someone out. Thanks
Old Aug 5, 2009 | 11:32 AM
Anyone?
Old Aug 5, 2009 | 01:13 PM
jaysgtp360's Avatar
watch out for new fuel additives....shell "nitrogen" speedway "stp" etc...I have seen this ever since the gas companies started adding other chemicals to the petrol...they say it is to clean and it helps for storage and shipping...I think it is just like watering down alcohol at a bar to get a couple extra shots out of the crown royal....anyway my brother in law works at an oil company and has shared with me all the new additives are causing volume problems in the the test fuel cells. This is what the fuel companies are trying to figure out now...we are the experiment..or I should say our cars are part of the experiment...anyway there are 2 main parts of fuel that our engines can meter...one is volume the other is pressure...if you change the volume the pressure has to compensate either up or down...if you use the new e-85 you will burn out injectors because of the duty cycles trying to compensate for something that is not happening...it is just fooling the computer because the chemical make up is different...I guess this is the long way around the barn...in short watch where you get your gas...try sunoco or any other non-middle eastern petrol station...you will probably see it all go away....
Old Aug 5, 2009 | 01:31 PM
ShortStack's Avatar
Well thats a good explaination.. but thats not what is going on here...
Im not sure why our cars do this, but when we hit under a 1/4 tank (closer to the 1/8th mark) we actually start running leaner AFR's... This was even printed in my hahn turbo kit manual...
