I have some choices to make
Old Jun 14, 2007 | 10:28 AM
chipmonk212121's Avatar
Originally Posted by johnkb8
that sub fits in our stock set up 100%
will it sound good with all other stock audio **** in the car
if so, i want that sub!
when i removed my sub from the car, there was about 4" of depth to work with. So that will be shallow enough. The only thingI noticed is that it has 6 mounting holes while our stock system is 8. So you would have to drill holes in the mounting frame of the sub, which shouldnt be hard. the stock amp is a 270 watt 6-channel amp. I am going to take the wires running to the stock sub and run them to an amp that I will mount on the opposite side of the car. There will be a small amount of fabrecating, but not much at all really.
Anyone else have any input on this?
Originally Posted by LSJinTN
you will NOT void ur warranty... there is no way the dealership can say **** about a smaller pulley... it's not like they're gonna take out ur injectors and look at them, and they certainly can not see the tune on ur car
stage kits come from the factory, if u get something equal to that, u can not void your warranty, and if they give you ****, the magnuson moss act will be your best friend
If you use aftermarket parts, or a non-gm tune, and they find out, you will have problems. Stage kits do not come from the factory.
Last edited by chipmonk212121; Jun 14, 2007 at 10:28 AM. Reason: Automerged Doublepost
Old Jun 14, 2007 | 10:34 AM
LSJinTN's Avatar
Originally Posted by tkaugh29
a little off topic but do you think i could buy the stock poineer sub/amp combo from the dealership? like the stock system is wicked but if its decent enough price why not get another, put it on the otherside...
back on topic, dont pay to get your system installed, maybe a deck if your doign that but a sub is simple, not to mention, if u didnt notice the battery is in the trunk, so to hook up a sub it would take like 10 minutes.you dont have to run wires or anything, just to the deck.
why would he get a head unit? the stock head unit is just fine, it does pretty much everything except for play dvds and give you a blow job... if he went audio, all he'd have to do is get the subs, box, amp, and a line level converter
bullshit, chevy cant tell ur tuned... how are they gonna know? i think hp tuners is a little better than a gm tune there buddy, as long as u have someone that knows how to tune cars, it'd be fine... gm has stage kits from the factory u dingleberry...
Old Jun 14, 2007 | 10:39 AM
cobi's Avatar
There are ways to tell if settings have been changed with the PCM, and the Stage kits are not factory they are GMPP
factory means it comes on the car when it gets to the dealership dipshit. and they can look at your PCM
Old Jun 14, 2007 | 10:44 AM
ptrblkz24's Avatar
How do you figure?If the car did not come from the factory with that pulley,they will void your warranty if your motor blows.Plus,any technician that knows what they are doing can look at the pulley and know if its stock or not.
You guys swear that act will protect your ass.If they wanna void your warranty,they will.Its happened before.
Old Jun 14, 2007 | 10:47 AM
LSJinTN's Avatar
why the hell would they read the PCM? if he had probs w. the car, its not hard to re-flash it u dick hole... im trying to give valid info here and am being criticized, why dont u smoke my pole and get off my ass... it's a lot cheaper to diy, then have gm do it for 1k+ if the tune is = to that of the gm tune, they can not say **** about it, bc IT COMES FROM THE FACTORY ALSO
and i do believe he could also run a 2.8 pully on the "stage II" flash, and on the 42.5 lb injectors, all he would have to do is switch it out to the 3.0 pulley if he had problems
Old Jun 14, 2007 | 10:59 AM
cobi's Avatar
If the car has problems running chances are they'll take a look at the PCM if its going to save them money and labor. Yah its cheaper to diy but some of us cant afford to jeapordize the warranty, and if your not lazy you can get it for about $650-800 installed.
And the tune will not be = to that of GM's otherwise why would you custom tune? He could run that pulley and switch it back if he had to go to the dealer but hes still maxing out the injectors. The stage II pulley is also 3.1" not 3.0".
Old Jun 14, 2007 | 11:00 AM
you are being retarted and have no intelligent words to say. so please stop trying
Old Jun 14, 2007 | 11:08 AM
LSJinTN's Avatar
are you ******* serious?
have ANY of you ever rebuilt and lsj, or let alone take one apart? have any of u have pcm problems? and chipmonk have u even read the gm build book?
he would use hp tuners is for tuning for stage II reasons only,not doing antything custom
Old Jun 14, 2007 | 11:09 AM
cobi's Avatar
Never completely rebuilt one, but have worked on them. Yes I have had PCM trouble.
If its not from GM and it changes the tune then it is custom.
Old Jun 14, 2007 | 11:12 AM
  #36
LSJinTN's Avatar
ive had my pcm replaced bc it was fucked hardcore...
hp tuners can give you a similar tune to that of a stage II tune...
most of the time dealerships dont know wtf they're doing anyways w/ this car
Old Jun 14, 2007 | 11:18 AM
  #37
cobi's Avatar
ok........
HPtuners can also result in a fooked car because of one tiny screw-up. This is why if they know the tune is not theirs they'll tell you to go pound sand. Stage II may not be the greatest tune in the world but with the heat from the Eaton it keeps the car within safe operating limits.
your right most dealerships dont know a whole lot about it. However they do know what to look for when it comes to abuse and modifying the car and trying to **** them over. If they get serious one visit from an engineer and your powertrain warranty can dissapear. Its not worth the risk IMO......
Old Jun 14, 2007 | 11:25 AM
  #38
LSJinTN's Avatar
ok........
my point was that he could do it himself for a lot cheaper
Old Jun 14, 2007 | 11:27 AM
  #39
cobi's Avatar
He also said this......
If like to NOT void my warranty....
  #40
the build book has nothing to do with this.
Old Jun 14, 2007 | 02:04 PM
  #41
snowdude1026's Avatar
Wow. my topic turned into a battlefield...
And yes I know I could find a mechanic to do it cheaper for me if I bought the kit online or something, but again I dont want to jeapordize my brand new cars warranty. Also, I am very NOT HANDY with anything that has to do with mechanics of an engine and even installing anything electronic. Cant do it. I cant even change my oil! lol
Anyway, I was thinking for cheaper, I could get a cold air intake and a GMPP catback exhaust system. Both cheaper then stage 2 by like $300, worth it and someday if they still exist down the line, get a stage 2? Again, chevy wants $1025 for the stage 2 and told me itd take 4-5 hours, no less.
Old Jun 14, 2007 | 02:23 PM
  #42
cobi's Avatar
Order the Stage II and for that matter all your parts from CED (Crate Engine Depot). He is an actual dealer up around Chicago and cheaper than anyone else. Then have it installed at a local dealer or one that gives you the best price. Then voila, warranty retained and parts for cheaper
Thats what I did
Old Jun 16, 2007 | 12:30 AM
  #43
it is NOT 4-5 hours of labor... call up 2-3 other dealerships in the area and ask them how much labor is required to do it. its like 2.5 last time i checked. they are just trying to rip you off. the S2 will be 10x better upgrade compared to an exhaust and intake. an exhaust installed will probaby cost 650 or so.
Old Jun 16, 2007 | 08:21 AM
  #44
RJSS's Avatar
You just need to find a dealership that doesn't suck. I bought the stage 2 and exhaust from crateenginedepot and had a local dealership install them both. They charged $300 to install the exhaust and stage 2! Sure there were some dealerships that I called that wanted a lot more or required that I buy the parts from them, but just don't go there then. The closest dealership to my house wanted $750 for the stage 2 and like $600 to put it on. When the guy told me that I almost started laughing. Shop around and you can find a good deal. My total for the S2 and exhaust with tip was $1300 shipped to me and installed by the dealer to keep my warranty.
06MetallicBalt
Jul 20, 2025 08:47 PM
dennis69
Oct 20, 2015 04:49 PM
Stuff
Oct 1, 2015 05:47 PM
OPCrer
Sep 27, 2015 08:11 PM
jas09ss
Sep 26, 2015 01:06 PM
