i have two ss sc's!!!
well sorta. heres the story.. my buddy eric hit a something in the road while cruising. bending the frame. totaling the tranny, rear sus and clutch. engine is fine. ide like to take his engine out and turn it into a super lsj (non turbo) any ideas or suggestions?? i pick it up on wed
well sorta. heres the story.. my buddy eric hit a something in the road while cruising. beinging the frame. totaling the tranny, rear sus and clutch. engine is fine. ide like to take his engine out and turn it into a super lsj (non turbo) any ideas or suggestions?? i pick it up on wed
Easy power!
But I do like it!
^The guy making fun was just joking around. (I hope) Just shrug it off.
at least he try ("like i do") and oh wait? he's the one speaking more than one language. pissoff
Chill guys... dont ruin the thread... Who cares how someone posts in a forum. This place is for gaining knowledge about our cars, not english.
The C1 headunit is about 2100ish.. dont quote me on that but i will let you know in a couple days when i order mine. Its completely worth the money. You can then put a Cobra H/E and a dual pass plate on and be set. 500whp would be cake. Running aprox 20psi?
Not calling bs, just dont see it happening..... maybe if you raise the comp and run race gas but not on 9.5:1 comp and pump gas....
IIRC... That Tag turbo kit put down 323whp?? on 18psi and 404whp?? on 22psi I dont see any s/c making more than a turbo on less boost......
If you have to ask how much something is and your building a motor then you should forget about it. To fully build a LSJ motor your looking at at least 5-6 grand for a 500hp LSJ. Either way good luck.
Can you explain more on how you can make 500whp on 20psi with a procharger??
Many people who grew up around engines/racing (and who can't even spell their own names) are still able to tear an engine apart and properly rebuild it ...
Blindfolded.
So take the time to use a bit of common sense if you want people to read your posts.
That is a phenomenally ignorant statement.
Blindfolded.
Blindfolded.
