I need brakes
Old May 30, 2009 | 06:51 PM
07touringcoupe's Avatar
I need brakes
Iight its about that time. I need brakes but since i do i was planning on getting rotors and pads and doing them all at the same time. So Where can i find some cheap cross drilled and slotted rotors? Also which are better pads ceramic or oem?
Old May 30, 2009 | 07:21 PM
Stevo's Avatar
nga is having a sale on brakes right now Id say theyre pretty good. Im ordering some powerslots and hawk hps pads heard they were both really great!
Old May 30, 2009 | 08:28 PM
Do u have a price for rotors and pads all the way around or a website
Old May 30, 2009 | 08:30 PM
blue05ss/sc's Avatar
x2....im ordering my brakes on wednesday...there r cheep brakes on ebay but idk if i trust them
o and i wouldnt get anything but ceramic
Old May 30, 2009 | 08:35 PM
Does anyone have a website? And the difference between ceramic and oem pads?
Old May 30, 2009 | 10:06 PM
nicksredline's Avatar
if i was u i would get the 1's on ebay some people use them and love them all around is actuily pritty CHEAP .. soem 1 will soon chime in here..
Old May 31, 2009 | 02:46 AM
Zach06CobaltSC's Avatar
ottp's ebc setup or powerslot setup.
http://www.ottperformance.com/Cobalt...114/index.html
Old May 31, 2009 | 11:00 AM
O ok so still no answer on the difference bewteen ceramic and non ceramic brake pads
Old May 31, 2009 | 11:13 AM
07SS_chick's Avatar
i believe the ceramic creates less brake dust
Old May 31, 2009 | 03:04 PM
NOLAGSS's Avatar
non ceramics will wear out faster and cause more brake dust to show up on the wheels. they also dont do well with heat the hotter they get the more wear they will show... they are also called organic pads... these are the pads people usually put on there car right before they sell it..... ceramic pads have a higher heat tolerance.. when they get hot they still wear but not as fast. also they reduce brake dust alot compared to organic pads. only problem i hear people complain is there queel loud in the morning.. this is because there cold once they warm up they quite down.... go with ceramics or semi ceramics at the least u wont be disappointed.
Old Aug 7, 2009 | 09:14 AM
Question how does the rotors come off on these cars? Are they freefalling? A bolt? Pressed on?
Old Aug 7, 2009 | 10:26 AM
I'm not sure how the rotors are on the car, but I would like to give my 2 cents on my system. I switched from stock rotors/pads at 60k roughly to power slot rotors and hawk hps pads and to be honest I really am not that impressed. I feel like I really have to lay into the brakes MORE to get the car to slow down and or stop. They work and do there job, but it doesn't feel as good as the stock system in all honesty. I had a shop install the brakes so I really don't think it was the install, maybe a manufacturer defect I dunno. Either way if and or when these pads go I am going to try the ebc green stuff pads.
Old Aug 7, 2009 | 10:31 AM
Iight good looking out. Does anyone else know how the rotors come off
Old Aug 7, 2009 | 10:35 AM
camaromanss1992's Avatar
R1 brakes are def FTMFW, cheap and excellent braking. powerslots are overprices IMO, i got R1 slotted premium rotors and hawk hps pads. its a billion tmes better than stock
heres my thread with pics
https://www.cobaltss.net/forums/r1-concepts-169/new-brakes-pics-179092/
they are held on by little nuts on the studs, they are just used during assembly to keep them on. us a flat head screw driver to undo them then therotors slide off, thats what i did
Last edited by camaromanss1992; Aug 7, 2009 at 10:38 AM. Reason: Automerged Doublepost
Old Aug 7, 2009 | 10:50 AM
You talkin about it like those black clip things that have a hole in the middle wit like teeth? Those hold the rotor on?
Old Aug 7, 2009 | 11:19 AM
Snakes709's Avatar
I got my slotted rotors, hps hawk pads, braided stainless steal brake lines and brake fluid from tcmotorsports...really good quality. Cost me $650 shipped to canada. Seeing as my car had about 60,000km on it the stock rotors were on really good. Took me and my mechanic 3 hours with a 5lb sledge hammer and 2 bottles of anti-seize to get the rotors off.
Old Aug 7, 2009 | 11:23 AM
It took 3 hours to do all around or what? And where did you spray the anti sieze?
Old Aug 7, 2009 | 11:27 AM
yes those clips. just pry the teeth things outward and spin them off
Old Aug 7, 2009 | 11:30 AM
O ok gotta. Good looking out doesn't sound to hard
3 hrs seems about right. remember i also painted the calipers in that time, also the rear calipers have to be turned, not pressed, to get the caliper piston in. I didn't spray any antisieze, just used the supplied brake lub on the caliper bolts and back of the pads so they dont sqeak. i did spray brake cleaner on the calipers and rotors before final assembly.
Old Aug 7, 2009 | 11:38 AM
O so the rear ones have to be turned in ok what like use a c-clamp to hold the cailper shut and just simply screw them in? the fronts are pressed in? And I use a c-clamp to press the front in right. So how to get the calipers to open for both front and rear?
Old Aug 7, 2009 | 11:43 AM
i just used the old pads on the front caliper pistons and a c clamp to press them in. on the rear i took some needle nose pliers and turned them by hand, they have grooves in the piston were the pliers can grab onto. took a little longer but i didn't have to use the GM piston tool to do it. once you look at it u'll see how easy it is
Old Aug 7, 2009 | 11:47 AM
So how do you get em both opened?
Old Aug 7, 2009 | 11:48 AM
i just told you
Old Aug 7, 2009 | 11:51 AM
O my bad. I mis read it. So that was basically how to take them open em and close em. Iight cool
