I need help ASAP. .!Starter!.
Old Oct 29, 2011 | 04:26 PM
mason753's Avatar
Exclamation I need help ASAP. .!Starter!.
Okay so.. I've currently been doin a motor swap on my Cobalt and am completely rewired exept I can't remember how the starter was wired. I know there's some wire that goes from under the head light and the fuse box down to somewhere around the starter. and theres like three really really small wires that look like they'd be grounds cause they aren't red or anything. I'm not really sure at all how this damn thing is wired. That's about all I need and I can drive my car again. Please and thank you. Any pics would be helpful.
Oh yeah! there's a yellow sensor I can't remember where it goes it lays around the tranny. any ideas.?
THANK YOU, THANK YOU, THANK YOU.
Old Oct 29, 2011 | 07:46 PM
mason753's Avatar
bumpp it up
Old Oct 30, 2011 | 04:39 PM
mason753's Avatar
bumpp, anyone?
Old Oct 30, 2011 | 11:28 PM
mason753's Avatar
Please????
Old Oct 31, 2011 | 12:05 AM
NVMYCOBALTSS's Avatar
PM Chood711. He may have them memorized from his clutch install ordeal.
Old Oct 31, 2011 | 12:41 AM
ItalianJoe1's Avatar
The big power wire from the fuse box goes to the large terminal on the starter. There is also a smaller one going from that same terminal to the alternator to power it. The smaller power wire coming to the smaller terminal on the starter is distinguished by it's slightly larger diameter than the other wires around it, but it's part of the harness still. That should be it.
Old Oct 31, 2011 | 11:37 AM
mason753's Avatar
don't know anything about he 3 really small wires?
or the yellow sensor
Old Oct 31, 2011 | 06:51 PM
robertmichaels's Avatar
post a picture of the small wires and sensor,
and like ItalianJoe1 said, the large wire from the fuse box runs to the starter (it is taped to the engine ground wire at some points)...then from the alternator their is another big wire that runs to the same terminal on the starter as the power wire, and then the only other wire is the signal wire, which goes on the small stud on the starger (i think its an 8mm nut) and the power is like a 12mm
by chance are these the wires you are talking about??
if so..the 2 bigger ones up close are ground wires and the small one in the background is the starter signal wire...
the 2 ground wires from the pic above go with the ground bolt that gets bolted to the trans
(the bolt is the one by my pointer and middle finger on the pic below, and the red wire goes from the starter to the fuse box)
Old Nov 4, 2011 | 12:09 PM
mason753's Avatar
Thanks, she started right up. Thank you all. Successful motor swap.
Old Nov 4, 2011 | 02:32 PM
glad to help
Gugi96
Sep 15, 2015 12:24 AM
juandirtymessican
Oct 27, 2012 10:41 PM
WopOnTour
Nov 27, 2006 10:10 AM
WopOnTour
Aug 19, 2006 07:05 PM
WopOnTour
Aug 19, 2006 02:48 PM
