I Need Some Help Now Guys!!
Old Dec 21, 2007 | 06:19 PM
streetrcer909's Avatar
Question I Need Some Help Now Guys!!
I just dropped the ss/sc off to get an oil change and go to pick it up after work and i turn the car on and have acel and just figured they hit tsomething and i would get it checked tomorow. I go to leave and as soon as i hit 5 mph it says engine power reduced and the car shuts off the engine is bogging and its fucked up what do you guys think happened? it was fine when i dropped it off but now its all fucked up. the garage is closed for the nite and doesnt open till 8 what did they do it? what do you guys think is wrong? it was fine when i dropped it off last nite....
Old Dec 21, 2007 | 06:21 PM
ecotecon18s's Avatar
sounds like they left something unplugged...prolly a sensor they moved to get to the oil filter...
Raven SS's Avatar
did u get it done at the dealership?
Old Dec 21, 2007 | 06:25 PM
liolixli's Avatar
To get to the oil filter in the ss/sc you have to reach through a bunch of stuff. Make sure they didn't pull off a wire or mess up the hoses. Check the oil and make sure they actually put it back in knowing gm work lol. While you are at it make sure it looks new because they have before just reset the life and not touched the oil if it looks ok. Make sure the intake is still connected well too.
Old Dec 21, 2007 | 06:27 PM
InfinityzeN's Avatar
Please be at a dealership and not some quick oil change place.
Old Dec 21, 2007 | 06:30 PM
no i got a jeep dealership that has been doing my oil changes on the ss/sc since ive had it friends of the family for longer than ive been alive (20 years) haha so they know what there doing to the car. It pisses me off cuz it was fine when i dropped it off and im ready to ******* kill someone rite now, does it sound like it could be something big? the only thing that worries me is it says engine power reduced then shut off
nope i trust this dealership with everything they installed my intake for free and would trust my car with them for anything that needs to be done. Just pisses me off cuz its fucked up now and was fine when i got there and there closed now so i dont know whats wrong with it
Last edited by streetrcer909; Dec 21, 2007 at 06:30 PM. Reason: Automerged Doublepost
Old Dec 21, 2007 | 06:31 PM
Raven SS's Avatar
if u trust them take it back and ask them what the **** over
Old Dec 21, 2007 | 06:33 PM
plan on it at 8 am when they open up just figured id c wat u guys thought it was and if i should be worried
Old Dec 21, 2007 | 06:35 PM
trent_ky's Avatar
look around in your engine bay and see if anything looks wierd...does it have oil in it?? also it could possibly be a clogged cat that just randomly started causing problems like mine did
SS/SC05/19/05's Avatar
I hd the same problem happen to me. I got out of the parking lot and my car says engine power reduced. Its a sensor they forget to connect. Its prolly the one right over the filter they forgot to connect
Old Dec 21, 2007 | 06:38 PM
cant see its dark out and garage is c losed. hopefully its just a bad connection and nothing big
Old Dec 21, 2007 | 06:48 PM
SScobaltSC's Avatar
they make flashlights so you can see in the dark........
Old Dec 21, 2007 | 06:54 PM
cars back at the garage and i got no ride out there
Old Dec 21, 2007 | 07:03 PM
jimbos'ss's Avatar
barometric pressure sensor is disconnected, your throwing a baro correlation error, probably p0069
it's sensor #2 in the diagram
Old Dec 21, 2007 | 07:59 PM
badasscobalt1986's Avatar
check the sensors and then turn the car on and off three time to reboot the system it happened to me when i let a garage change the oil luckily there was i guy there who had like 20 years working at chevy. and also check to see if they put snythetic oil in it or just regular when it opens. and slap the hell out of the guy who did the oil change.
Old Dec 21, 2007 | 08:00 PM
i bought mobil one oil and filter so they used that on it
Old Dec 21, 2007 | 08:04 PM
check and double check the sensors. and if that doesnt work take to the dealership.
Old Dec 21, 2007 | 08:05 PM
would that cause me to lose engine power and have the idle all fucked up?
Old Dec 21, 2007 | 08:48 PM
jimbos'ss's Avatar
yes allready had the same thing happen to me
Old Dec 21, 2007 | 09:07 PM
Mattman6's Avatar
yes because only competant GM techs that charge double know how to do an oil change correctly
Old Dec 21, 2007 | 09:10 PM
jimbos'ss's Avatar
QFT, i take mine to a lube shop and talk them through the process, sometimes i even help them when they can't figure out how to get the filter cap off.
They call me 'E''s Avatar
Well, if the engine thinks something is wrong, anything is possible, so yes, that could be and probably IS the reason.
Old Dec 21, 2007 | 09:26 PM
k guys i just went down to the garage and there was a sensor diconnected it was rite under the supercharger so i plugged it back in and its working fine now still have the cel but i get that cleared tomorow thanks guys!
Old Dec 21, 2007 | 09:29 PM
Thats strange because the dealership actually charges me less then the lube shops for an oil change with Mobile 1.
Old Dec 21, 2007 | 09:32 PM
my dealership charges 80 bucks for an oil change with mobil 1. and the garage i go to is 20 bucks for oil change 10 bucks to rotate tires if i supply my own oil so its a hell of a lot cheaper
