iat2 help please
Old Jul 29, 2009 | 04:25 PM
Hockeyman's Avatar
iat2 help please
I have the large CXR h/e running in series and meth with a 3gph nozzle as my cooling mods, with a 2.8" pulley. Went to do a few logs today, weather is 90*. IAT1's hover around the 110 mark and climb to 120* when I floor it. IAT2's go near 160 at redline during 2nd and near 180* at redline in 3rd. I know these numbers are way too high, especially since i'm running meth. IAT2's drop to 140* within seconds of letting off. My IC pump works, it's tuned to come on when the key is at "on" and i can see coolant bubbling and running. Is it possible for the IC pump to stop working under WOT? There is no air in the h/e and my meth is spraying, no idea why my numbers are so damn high. Timing is being reduced because of this and it's beginning to **** me off.
Old Jul 29, 2009 | 04:29 PM
flash13brandon's Avatar
Are you running option b or extra tank to bleed the system easier? My only guess would be air in the system. If you're temps drop that quickly after than your pump seems to be working. It's hotter down here and I have CXR h/e, meth, dual pass, and extra tank and my temps never get over 160 on a 2nd-3rd gear pull.
Old Jul 29, 2009 | 04:33 PM
Hockeyman's Avatar
I don't have dual pass or option B, I don't think there is an air pocket but maybe I should bleed everything out again.
Old Jul 29, 2009 | 04:40 PM
That's the only thing I can think of. Also, make sure none of the hoses are kinked(sp?).
Old Jul 29, 2009 | 04:48 PM
SCcobaltSS's Avatar
x2. and is your meth turning on? I was stock heat exchanger with the same mods at the same temp I was at about 140ish IAT2..
Old Jul 29, 2009 | 04:54 PM
1badBlueberrySC's Avatar
I had a 2.7 meth (5gph nozzle) and a Cobra h/e
Did 4 back to back runs at the track ITA2's never got above 117*
SO there is something deff. amiss
Old Jul 29, 2009 | 05:37 PM
rico's Avatar
has to be air. with dual pass and extra h.e i was getting super high Iat2's until i bleeded my h.e again and that solved it
Old Jul 29, 2009 | 05:50 PM
EatonTVS07's Avatar
i think deathsythe was having similar problems. something about a sensor or somehting i dont really recall, but ask him.
Zach06CobaltSC
Jun 22, 2008 06:00 PM
Scoot05RedSS
Mar 31, 2008 10:54 PM
LopsidedJester
Sep 1, 2007 10:54 PM
Blown 4-banger
Oct 24, 2006 06:25 PM
