Iat2 temps
Old Sep 20, 2011 | 05:34 PM
microgab's Avatar
Iat2 temps
Hey everyone, just wondering what are your iat2 temps!
When I WOT, it goes over 180 and my regular driving sits around 150. My pump wasnt working so I smacked it with a hammer and its back to life. So its working for now, but the temps are still the same as yesterdays.
What you I do to lower my temps to a normal, safe temperature. I have a zzp #3 heat exchanger, injen 2.5" coi, 2.9" tvs
Thanks a lot!
Old Sep 20, 2011 | 10:10 PM
mrbelvedere's Avatar
put a pump on it
Old Sep 20, 2011 | 10:55 PM
ecot3c inside's Avatar
pump for sure needs changing. my m62 with a 2.8 and no name h/e doesn't get over 150 on a hot and humid day WOT
Old Sep 20, 2011 | 11:16 PM
ben_gary's Avatar
Dual pass endplate
Old Sep 21, 2011 | 06:17 AM
Originally Posted by ben_gary
Dual pass endplate
no
Old Sep 21, 2011 | 08:14 AM
microgab's Avatar
Alright, so its the pump for sure then? lol
Old Sep 21, 2011 | 08:15 AM
umrdyldo's Avatar
Stop beating on the car and change the pump.
Old Sep 21, 2011 | 01:52 PM
ben_gary's Avatar
Ok. I read one part where he was asking How to get lower IAT2s.
Old Sep 21, 2011 | 02:51 PM
get a zzp phenolic spacer
Cobalt & Ion ---> ZZ Performance
and put this on the fron and back of the lower intake manifold
Design Engineering DEI 010393 - DEI Reflect-A-GOLD Heat Barriers - Overview - SummitRacing.com
Old Sep 21, 2011 | 03:44 PM
sjc0013's Avatar
Window Licker
I apologize for the threadjack, but lol, I saw 190* doing 2 highway pulls, what the hell is going on? the first pull i let off at around 110 mph, and then the second one around 120 mph. I just replaced my ic pump maybe a month ago or so, so that isnt the problem. I wanted to do a few good pulls on the tvs but as soon as i saw 190 i was like holy **** i think thats enough for the day. I have the ottp h/e. Why were my temps so high after 2 pulls?
Old Sep 21, 2011 | 08:02 PM
05_blue_ss's Avatar
I'm running 180 during driving but when I sure at idle it goes from 200_220 then it drops back down. My car us stock minus the air box mod
Old Sep 21, 2011 | 09:16 PM
sjc0013's Avatar
Window Licker
We aren't talking about engine coolant
Old Sep 21, 2011 | 10:46 PM
05_blue_ss's Avatar
whoops my fault and that is why I'm cautious on what I post.lol
Old Sep 21, 2011 | 10:54 PM
sjc0013's Avatar
Window Licker
its all good man
bump.....anyone wanna chime in?
Old Sep 21, 2011 | 11:00 PM
air in the system will cause that
Old Sep 21, 2011 | 11:18 PM
sjc0013's Avatar
Window Licker
How can I tell if i have air in the system? I also was thinking about this when I installed my option b, I used a 90 degree fitting to run the 3/4" hose from t fitting to the opt b tank, do you think this is hurting me?
Old Sep 21, 2011 | 11:22 PM
if the option b isent hooked up correctly it can did you install the bleed line with the restrictor orfice in it
Old Sep 21, 2011 | 11:55 PM
sjc0013's Avatar
Window Licker
yep
Old Sep 22, 2011 | 12:03 AM
defo98's Avatar
no
Uhh... YES. A great improvement when I installed mine took longer for the temps to reach high and cooled down much quicker... but you definately need a pump first OP
Old Sep 22, 2011 | 09:18 AM
microgab's Avatar
I think I'll get another pump tonight from zzp. It doesn't seem to work correctly. Might as well get the Option B and dual pass at the same time. Seems a bit complicated to install tho
Old Sep 22, 2011 | 09:21 AM
CobaltVenomSS's Avatar
yea my option B took about 3 weeks for it to work right...i ran the car with the lid off for about a week then it started to run right lol
Old Sep 22, 2011 | 09:37 AM
zerosk8ter83's Avatar
I made my own opt b tank and it was working as soon as the pump came on
Old Sep 22, 2011 | 09:44 AM
ChrisR1S's Avatar
Homemade option b, zzp s3, dual pass, zzp phenolic spacer, and meth that comes on at 8psi. I have never seen over 120ish after back to back pulls on my 2.7.
Definitely get a working pump and then get all the cooling mods you can afford
Old Sep 22, 2011 | 09:53 AM
will that spacer fit my ls or will it have to be modified?
Old Sep 22, 2011 | 11:16 AM
sjc0013's Avatar
Window Licker
Hmmm maybe I will try this, there must be air in my system bc my temps should not be that high. Diggin the new sig btw.
