I'm going E85
Old Mar 1, 2008 | 07:09 PM
Onyxd04Redline's Avatar
I'm going E85
They FINALLY started selling E85 in the valley. Whoohooooooo
Old Mar 1, 2008 | 07:23 PM
cobalt9123's Avatar
goo fo you!
i'm runnin on chicken grease.
whitted2268's Avatar
Congrats
Old Mar 1, 2008 | 07:39 PM
srowler9's Avatar
What needs to be changed to run E85?
Old Mar 1, 2008 | 07:43 PM
Bigger injectors and a tune
Old Mar 1, 2008 | 07:44 PM
Projekt's Avatar
onyx! i need your help! buying a car from your dealership! pm me!
Old Mar 1, 2008 | 07:45 PM
WickedSS2005's Avatar
And the correct fuel system components to not corrode from the ethanol
Old Mar 1, 2008 | 07:46 PM
Eddie's Avatar
i'd becarefull cuz ur boosted, one of the reasons why the vette ZR1 didnt go E85 was because of boost, the E85 fuel delivery couldnt meet the requirements for the supercharger. so i'd look into it a lil more.
There is already a guy on the forum who is running E85 in his cobalt SS. Fuel system is stock i believe except for 60lb injectors
Old Mar 1, 2008 | 07:47 PM
3fo893013L's Avatar
what car are you putting E85 in?
freakta's Avatar
i thought all gms would run it from the factory
My Redline
Old Mar 1, 2008 | 07:48 PM
Eddie's Avatar
really? wow thats sweet. closest E85 place here is 35miles away.
Old Mar 1, 2008 | 08:16 PM
Rodimus_Prime's Avatar
you need HUGE injectors the AFR needed is like 8s or 9s
Old Mar 1, 2008 | 08:18 PM
DWK5150 is the member on the forum who is running E85 and he's running 60's. I'll wait for him to chime in.
3fo893013L's Avatar
My Redline
is that even safe? I heard the harsh E85 can eat gaskets and such if used on a frequent basis.
Old Mar 1, 2008 | 08:19 PM
All talk. No proven facts. GTP and mustang guys are running E85 on non designed E85 cars for awhile with no problems.
Old Mar 1, 2008 | 08:32 PM
3fo893013L's Avatar
question on E85. Essentially E85 I know is a high detergent gasoline/ethonal (spelling), like 100 octane in rating, on even some of the more 2005+ modern cars it shouldn't have a problem running it if you decide to pull up and pump it? I'm confused. I know that GM makes E85 octanes maps in the ECM for so called "high octane mode" for those who are equipped to supposedly run E85.
Solid proof of uses without issues down the line?
Old Mar 1, 2008 | 08:51 PM
Herndon_High_SS's Avatar
Bump for more info.
Old Mar 1, 2008 | 08:55 PM
redlineblueline's Avatar
as per the owners manual ethanol fuel is compatible with the stock fuel equipment in the cobalt systems however methanol is not
Old Mar 1, 2008 | 08:57 PM
Red2.4SS's Avatar
I thought about it but there are still no stations near me!
Maybe later, then a tune. The higher octane would be sweet!
Old Mar 1, 2008 | 09:00 PM
Smarty Art's Avatar
If you use that stuff with what you said your doing you won't have any problem. It's down the road when the components are exposed to it over time.
Old Mar 1, 2008 | 09:01 PM
105 Octane > 91 octane
Old Mar 1, 2008 | 09:03 PM
tREBs's Avatar
hmmm interesting.... subscribed
Old Mar 1, 2008 | 09:04 PM
Mines_Better's Avatar
if this is true then i might fo grab some soon. is it really expensive? there is a station about 15 minutes from me
