I'm rich bitch!!!
I'm rich bitch!!!
OK got the aem uego intstalled and im running a 10.9 a/f ratioe at 7 rpm at wot. I have a stage1 with 2.85 I thought that was a bit unusual with the pulley being borderline maxing things out and people blowing up. Also this isnt a fluke becaue silverss had same exact mods and gauge and had same results. So am i safe? should i get tuned? Anyone else see the same thing?
I don't know what all your mods are but I would also recomend an intake as that will lean you up a bit as well as get you more hp and better gas mileage (if you keep your foot of the gas peddle).
It's something in the tune. Try and get a good tune, that should do it.
Realize the Gm Tune is a year-round tune, which means it is safe! you will not tear the car up on this tune. How often do you hear of people damaging pistons on a stock gm flash? Never. The people who are having piston troubles are tuning it themselfs for more power and risking reliability.
Nick, you have seen what a tune does (duys car) and a very good tuner tuned it. [look who he got beat by]. Spend the money else where. That Gm tune is so safe, ive seen people spray a little 50 shot and be fine without touching the timing, refer to the user "zinner" on here.
i read somewhere here on the forums that the cobalt like to run rich which means ur safe...usually good points for the balt are 10.6-11.4..other cars are mid 11's
i like the charlie murphy comment. "Darkknessss!!!!"
dont believe what you read on forums, especially off this one, with many uneducated teenagers giving advice on cars when they have had a license for 2 years. Your correct on your "good points" but not every car has the same "good point, or sweet spot for that Air Fuel" Cobalts do run rich from the factory, start modding them and things can change, be careful guys.
http://en.wikipedia.org/wiki/Air-fuel_ratio
Narrowband or Wideband?
He was trying to tell me that his intake and step 1 colder plugs dropped his IAT by 12 degrees. I was like::Well hows that possible, how did you determine a 12 degree drop? And he told me b.c of his coolant temp. i was speechless at that point....
I later asked him hows that possible when plastic dissapates heat better then metal? , gotta love um!
im down to go **** with some stupid noobs whenever, so let me know
you shouldve stayed.
JonyyB
10-04-2004 09:49 AM
