Immediate Help Needed!!
Old Jun 15, 2008 | 09:02 PM
Zach06CobaltSC's Avatar
After installing my B&M Shifter, I took it for a drive and got reduced power. I then realized after calling a friend my maf was unplugged. I plugged it in, but still had the reduced power.
These are the codes.
p1101
p1182
p0068
p2228
can someone please let me know what these mean, or give me a "code" site. Thanks.
Old Jun 15, 2008 | 09:44 PM
Julex's Avatar
Dtcs' are
p1101- intake airflow system performance - pcm detects that actual airflow by the maf,scip, and tp sensors does not correspond with calculated airflow for more then .5 seconds
p1182 - supercharger inlet pressure(scip) sensor performance - actual airpressure by the scip does not correspond to calculated airpressure for more then .5 seconds
p0068 - throttle body airflow performance - calculated airflow rate is more then expected for more then .2 seconds
p2228 - barometric pressure (baro) sensor circuit low voltage - pcm detects baro is less then 50 kpa for more then 8 seconds OR pcm detects baro signal voltage is less than .51 volt for more then 8 seconds.
Clear dtcs (unplug battery for a few mins if you don't have a scanner) and restart.
Old Jun 15, 2008 | 10:20 PM
Alright, the guy thats going to help me install my CAI tonight said not to touch my car and he would fix it. He said that he knows exactly what it is and we are fine. I dunno though, I am really worried that the MAF is broke or something. He is about 5 minutes away. He got pulled over for doing 50 in a 35. So he's running a little bit late lol.
julex - i do have an interceptor, if he says its fine to clear the codes, after he is done installing the cai, or even before, or whatever, then i will. Basically I am just waiting for him to get here now.
Codes are cleared, no more codes. However instead of a temp reading next to my mileage I have a ---
what the hell does that mean?
It says
--- 32383miles basically
Last edited by Zach06CobaltSC; Jun 15, 2008 at 10:20 PM. Reason: Automerged Doublepost
Old Jun 15, 2008 | 10:22 PM
Julex's Avatar
clear them anyway, you know what they are.
Basically it sounds like it was just a fault when starting, nothing to do with shifter, probably just random. unless you did something more then just your shifter. I don't think it'd be maf sensor anyway worse case scenario, more like intake coupler loose or something of the likes.
Old Jun 15, 2008 | 10:25 PM
ilovecars's Avatar
how do you know when your car throws a code ? sorry i dont know much do you have like something that tells you?
Julex's Avatar
did you start it back up? let it run for 5 mins, then turn off and start again.
You will through a MIL on special codes, but some codes if not enough faults are hidden unless you have a obd2 scanner of some sort, HPT, intercepter gauge, scan tool, etc
Old Jun 15, 2008 | 10:30 PM
I have an interceptor and I cleared all of the codes. However I still am not getting my temp reading next to my mileage when i start the car. Instead its just a --- and stays that way. I am currently resetting the battery to see if it helps. Thanks.
Old Jun 15, 2008 | 10:31 PM
Cobalt_SSTuner's Avatar
it was probably because your maf sensor was unplugged. Plug it back in, clear the codes and take it for a drive.
heres a really basic but stupid question. did you put the maf sensor in the right way?
Last edited by Cobalt_SSTuner; Jun 15, 2008 at 10:31 PM. Reason: Automerged Doublepost
thatotherguy's Avatar
Your Check engine light will come on
Old Jun 15, 2008 | 10:32 PM
I unplugged the maf, plugged it back in, cleared the codes and took her for a drive and no luck. So, now i am unplugging the battery waiting a few minutes, plugging it back in, and then seeing if it works. If not, I will be really pissed.
Julex's Avatar
When you changed your shifter, did you go near any wires? did you have the battery unplugged? just wondering if maybe something arked or grounded itself, and shorted out.
Old Jun 15, 2008 | 10:34 PM
Plugged the battery back in, no luck. I am still not reading the temp outside. It just has --- and my interceptor is not picking up any codes.
powerz's Avatar
if you took out the head light you prob. pulled out the temp sensor
Julex's Avatar
Most codes require to be thrown more then 3 times to show, and not all codes will throw the MIL.
Sorry switching back to this every few mins, Go Celtics
Old Jun 15, 2008 | 10:35 PM
not always....
Julex, I was changing the short throw shifter but the day before my buddy was messing with my intake getting ready to install the injen cai, however it started to rain so he quit. So the codes above were because he unplugged the maf and something else. All the codes are gone, I have no CEL, although I will when my p0420 cat code comes back, but the interceptor isn't catching this problem.
hell yea go celtics....**** kobe
/off topic chat/
Old Jun 15, 2008 | 10:36 PM
sick06cobalt's Avatar
you may just have to wait longer bro.... its because your maf was not plugged in.... we came across these problems alot at the dealership i worked at...
did he take the maf sensor out? If so, check to make sure its not put in backwards
Old Jun 15, 2008 | 10:37 PM
as for the po420 delete the code or get a new cat.. its up to you...
My buddy did take the headlight out, and I think he did take out the temp sensor. He is checking now as we speak. GOOD call man, thanks a ton....still waiting to see....I hope its unplugged...common man.....please be unplugged.... YESSSSS ITS WORKING!!!
GOOD F'ING CALL!!! NICE JOB MATE!
::Off topic start::
I thought you were banned?
::Off topic end::
Old Jun 15, 2008 | 10:40 PM
Originally Posted by Cobalt_SSTuner
::Off topic start::
::Off topic end::
:Off topic response start:
I was... if you want more info pm me
:end off topic response:
Julex's Avatar
>.> lol that's why I try to only work on my own car, so I remember what I took out and what not, I had this happen to me when I did my custom intake a long long time ago. Good luck.
Old Jun 16, 2008 | 03:20 AM
Thanks mate. The cold air intake is now installed and all is good. Tomorrow we will be finishing up all the gauges, hiding the wiring, and then installing the meth kit. Later on at night, we will be doing the HID high and low beam kit. Wish me luck.
