Ingalls or motor mount!?
Old Nov 13, 2007 | 12:32 PM
Nyke's Avatar
So as I am installing my performance parts on my Cobalt I am looking at this Ingalls Torque damper. Cool thing great concept. however... what is the point of having an Ingalls if you have polyurethane motor mounts and tranny mounts?
Just want some feedback.
Old Nov 13, 2007 | 01:51 PM
bc3tech's Avatar
no point. motor mounts >>>>>>>>>>>>>>>> torque damper.
/thread.
Old Nov 13, 2007 | 01:57 PM
D4u2s0t's Avatar
you use one or the other, not both. solid motor mount is better, so stick with it.
Old Nov 13, 2007 | 02:09 PM
phatnackySS's Avatar
if you have mounts, the ITD is pointless, i had the ITD first , it helpd with wheel hop on the street ,and its great if you dont want to deal with vibrations , but for track use it dosnt hold up. i was going to get traction bars and see if the a ITD and traction bar combo would work, but insted i went the cheap rout and got engine mounts , the mounts fixed the wheel hop..... i recently just gave the stiffy to my wife ...after i gave her the ITD<joke drum roll> but anyway, i cant tell a diffrence now that its gone.
Old Nov 13, 2007 | 02:11 PM
Raven SS's Avatar
TTR engine mount is so nice..and if u dont have tranny mounts the ingalls has cracked some tranny caseings
Old Nov 13, 2007 | 08:42 PM
FryLoch's Avatar
Neither those are only for noobs, get a wheelie bar!
JK JK
The mounts no doubt
Old Nov 13, 2007 | 10:14 PM
tlax23's Avatar
Mounts.
Think of the Ingalls as a band-aid for your traction issues.
Old Nov 13, 2007 | 10:16 PM
KillerBee's Avatar
TTR motor mounts work so much better but if you dont like vibes get the ITD
Old Nov 15, 2007 | 09:44 AM
megaman311's Avatar
How bad are the vibrations? Does it mellow out over time? I had polyurethane mounts on my cavalier. It was rough the first few months, then it mellowed out a bit. I thought that the mount wore and broke, but after inspection, it was fine.
Old Nov 15, 2007 | 09:45 AM
D4u2s0t's Avatar
JK JK
The mounts no doubt
a wheelie bar on fwd... that would be interesting
Old Nov 15, 2007 | 09:47 AM
distillion's Avatar
i have the avid mounts(med) they do NOT produce false knock.
and the ingalls.
works great.
Old Nov 15, 2007 | 09:53 AM
smartmts123's Avatar
I really enjoy my mounts - the install wasn't too horrible (with the right equipment), and the vibrations aren't bad unless i'm right at 1800 rpm or so.
Old Nov 15, 2007 | 09:54 AM
D4u2s0t's Avatar
they're not that bad. you get used to them. people make it seem SO much worse than it is. i feel them a little in reverse, and when going from a stop. when driving they're barely noticeable. and when you feel the difference you don't care about the vibes.
Old Nov 15, 2007 | 09:56 AM
braineater's Avatar
the torque dampener is easyer to put on and will produce less vibrations but the motor mounts are more effective. so its a matter of taste really.
Old Nov 15, 2007 | 11:25 AM
ebristol's Avatar
Which top smm do you guys recommend? Bwoody or TTR?
I would ask the RLF guys but they sexually slurp Bwoody in their sleep! Its pretty pathetic.
And what about using a top smm (either TTR or Bwoody) along with a lower Ingalls TD? Or is that is a waist of time?
The reason I ask is because I don't want to go with a full smm set up because of the vibes. But with the lower Ingalls I could leave it loose for daily driving and then crank it down for the track.
Old Nov 16, 2007 | 08:31 AM
TurboTechRacing's Avatar
B Woody complete set is $260 (Trans and upper enginemount)
Turbo Tech Racing compete set is $239.98 (Upper mount and both trans bushings)
We also have a unique "square" bushing deisgn, that is specifically designed around this engine, and is not an "off the shelf bushing" It will help keep rotational forces down and also dampens the vibrations very well.
Old Nov 16, 2007 | 10:55 AM
Kibosh3's Avatar
i got the ingalls, i must honestly say that it does help with first gear especially, im sure the motor mounts do as well, but its ultimately ur choice
Old Nov 16, 2007 | 11:08 AM
LopsidedJester's Avatar
i don't trust torque dampers to make a huge difference. I had a torqueforward front and rear mount (which is probably a little worse in quality than ingall though) and i still wheel hopped and the there were still large vibrations from the rear mount as well as rattling.
Stiffer trans mounts FTW - I just got done filling in my transmission bushings with 3M black polyurethane windo weld for extra added stiffness. Its temporary til i build up enough money for full replacement mounts, but it helps put the power down and allows for smoother shifts and it only cost me $14.99. Slight extra vibrations from a stop, but its definitely no where near as stiff as replacement polyurethane mounts or prothane bushings.
Old Nov 16, 2007 | 11:45 AM
PuSha050's Avatar
When i do get an upper motor mount.. it definately will be TTR, their design is much more effective IMO
... the way i explained it to by friend who didnt understand why i thought it was better was this ----- squeeze one extended finger with your other hand and rotate.. spins pretty easily... now squeeze three extended fingers with your other hand and rotate.. not easy at all... cheap explaination but worked for him
all i have is both trans bushings right now.. the vibs are not bad at all and i HATE vibs with a passion.. my car is not a race car so i dont want it to feel like one u kno lol
Old Nov 16, 2007 | 12:05 PM
Very good basic concept!
Old Nov 16, 2007 | 12:12 PM
PuSha050's Avatar
feel free to use it at any time
Old Nov 18, 2007 | 12:32 PM
ebristol's Avatar
Yes but bwoody's complete set include 3 new engine mounts.
Your complete kit includes 1 new engine mount with 2 poly inserts.
I don't know if that is a fair comparision.
Old Nov 18, 2007 | 01:52 PM
BLK SS/SC's Avatar
im looking into a set of tranny mounts right now iv e had a ingalls torque brace since about 6 months after i bought the car so the motor mounts seem fine but the tranny are just about destroyed im thinking about gravanna or tubtech press in polyurithane and they are close in price think they are giong to make a differance
Old Nov 18, 2007 | 01:58 PM
ebristol - Why would you replace your stock aluminum casings for those welded up steel ones? You are not really getting any more for your money.
That is why inserts are popular, there is no need to put on a whole new tranny mount.
Also, the bushings are SO small on the B woody mounts you will get A LOT of vibrations.
Old Nov 18, 2007 | 02:06 PM
BLK SS/SC's Avatar
im not afraid of vibrations torcue brace gave me alot of that are they some what easy to install
at idle with just the ac on the tranny side moves alot and the pulley side does not move at all
