Installed today CAB's tran mounts my info on them
Old 07-30-2006, 01:24 AM
John's Avatar
well i just did like 3 or 4 first to second gear shifts hard and the wheel hop and banging of the engine is gone..
but with those to tranny mounts does the car ever shake (WOW)omg..
the shifts feel alittle smoother but i dont think its worth the rattle and shaking of the car
all in all they help for wheel hop but if u like a smooth ride do not buy mounts
i prob plan on taking them back out sometime this week
also doing the CAB's it throw off my alingment(not great speller)so there go's more money doing that
if anyone wants to buy those mounts off me ill prob sell them for 50 or 60 bucks lmk
Old 07-30-2006, 01:43 AM
mken's Avatar
They'll loosen up over time and maybe reach a tolerable level for you. It was certainly more vibration than I expected at first, but it is alot better now, just took a couple thousand aggravating miles. Since the front mount is easy to change (10 min. tops), I can switch it in and out between racing and long drives. Don't know which mounts you got, but you might want to give them some more time to break in and then make a decision later.
Old 07-30-2006, 01:59 AM
John's Avatar
i just got the inserts from intense
i also find it hard to belieave there going to work in
i was thinking maybe drill some holes in them what u think of that?
Old 07-30-2006, 02:45 AM
mken's Avatar
That's what I was told when I complained on these forums, too, didn't believe it either, but none the less, they have gotten about 50% better since then, just took awhile. As far as drilling holes in them, I haven't got a clue what that would do.
Old 07-30-2006, 02:56 AM
John's Avatar
well thanks for the info ill see what i do
Old 07-30-2006, 11:21 AM
SS33's Avatar
I'va also heard that a slightly higher idle reduces the vibrations.
I have the Intense poly tranny inserts sitting on my workbench, and stage 2 on order, so if I get the bushings installed before my stage 2 kit arrives I can test that out.
Any other opinions on this?
Old 07-30-2006, 11:56 AM
John's Avatar
well as i said if u like the smooth ride dont do it
this what i think if u dont want wheel hop do the CAB's and if u still have wheel hop get track bars
Old 07-30-2006, 12:03 PM
DTM2188's Avatar
When I first installed my ZZP Billet Engine Mount and Poly Tranny Mount, I had awful vibrations, but no wheel hop. After about a month the vibes have decreased a good bit, but I'm not gonna lie, there still there. I didn't think the vibes would decrease at all either after I felt how bad they were at first, but they did. But if your not a fan of getting vibrations at all, I would try to go an alternate route.
Old 07-30-2006, 12:06 PM
John's Avatar
ya i think the other route would be CAB's and track bars
those 2 togerther will reduse all your wheel hop and keep a smooth ride
Old 07-30-2006, 02:25 PM
uthinkimodd's Avatar
i just installed mine yeah it's worse then i expected but they will break in. i'm waiting for CABs and a new motor mount so it could be vibrating for a while.
Old 07-30-2006, 02:30 PM
distillion's Avatar
id say go for a motormount, the vibes arent that bad, the trans mount does give the most vibes, i have the cab's motor mount and lowered and my wheel hope is gone, with minimal vibs from the motor mount.
Old 07-30-2006, 04:01 PM
John's Avatar
ya i was just in Ed's car which just haves the motor mount and the vibs are very minimal
Old 08-06-2006, 11:47 PM
sportcycles's Avatar
For those that have installed poly engine and trans mounts:
Is it just me or is the distinct supercharger whine sound different now? Seems quieter. Maybe due to more noticeable engine noise inside now. What do you think?
Old 08-07-2006, 02:14 AM
mken's Avatar
There's definately more engine noise which in turns drowns out the whine, but the engine note does seem alot more aggressive, at least from inside.
Old 08-07-2006, 12:32 PM
yeah engine noise just kinda drowns out the whine. I haven't heard it from the outside yet though. I know when i turn on my AC the car shakes like crazy.
Old 08-07-2006, 12:38 PM
p7x
p7x's Avatar
The mounts will settle so some of the vibes wil stop but there will alwasy be vibes especially between 1-2k rpms. As well if you get stage 2 or some other power upgrade and a tune the engine will run smoother and the vibes will settle a lil more. i personally love the vibes.
Old 08-08-2006, 01:44 PM
SS33's Avatar
I now have the Ingals ETD installed with my transaxle mounts. And I love them, the vibes don't bother me at all. Especially when you put the boot down :-)
I think the Ingals took some of the edge off the vibes at idle. So if the mounts break in over time and the vibes get better I would say this isn't a bad route to go at all.
brickloaf
Show & Shine
56
06-18-2019 12:51 PM
insylem
10-01-2016 08:34 PM
no_ss
09-18-2015 11:03 AM
medic710
09-06-2015 08:53 PM
Josh@ottp
09-05-2015 07:46 PM
Quick Reply: Installed today CAB's tran mounts my info on them
