Intake Question
Old Sep 16, 2008 | 07:55 AM
Ilke2gofst's Avatar
Intake Question
Is there any other way to replace the filter without taking off the damn plastic guard in the wheel well?
Old Sep 16, 2008 | 08:00 AM
ls1fbody's Avatar
Haz l33t wheelz.
mmm... not unless you wanna take off the front bumper. taking the headlight off helps as well. actually taking off the headlight is one of the only ways, at least without pulling off the wheel and fender liner.
Old Sep 16, 2008 | 11:36 AM
rnjmur's Avatar
You don't have to take the whole plastic guard off. If you just undo the bottom clips and a couple on the front of the wheel well you should be able to pull the cover out of the way enough to get to the filter. There is no other way to do it. Removing the headlight and/or the front clip is NOT easier.
Old Sep 16, 2008 | 11:42 AM
kinggeorge's Avatar
removing the headlight takes all of 3 minutes and it is easier...
Old Sep 16, 2008 | 11:48 AM
arkkornkid's Avatar
absolutely, and you're unfastening bolts rather than those plastic body panel holders than never hold tight once you remove them
Old Sep 17, 2008 | 09:41 AM
Ilke2gofst's Avatar
Thanks for the info guys I was hoping I could just take the headlight off and get to it that way because I really dont feel like dealing with that splash guard again
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Sep 25, 2015 06:06 PM
