INTENSE is proud to bring you....
#52
Originally Posted by cvenom2122
if we have a bad compression from factory, with a better compression made for high boost apps mabe we would gaine 5 ponies and a more stable car
#53
Domestics Pwn
Originally Posted by FAST06SS
As for the price to install, we are offering a killer deal on installs at my shop, call me if interested. We are charging warranty time only, NOT book time which is inflated 40-60% over warranty!
I dont want to do them myself... Im still trying to get the energy up to change my clutch.
#54
These will void warranty correct? Man throw on some cams, pistons, stage kit, cai, and exhaust and we should see some balts putting down some fairly impressive numbers. I am deffinantly happy to see the aftermarket picking up it's coming along slowly but surely.
#55
#56
Originally Posted by Tofu
They shouldn't necessarily void the warranty...unless say someone got the 10.5:1 compression ratio and decided to put 87 octane with no tuning or means of reducing knock and blew their engine (theoretically of course). Simply swapping them however, I wouldn't see a problem with it.
#58
LSX RWD S/C conversion
As soon as you tear into your engine you will void your warranty. No car maker is going to warranty the workmanship of some unknown mechanic or some aftermarket product put in the engine. There are to many working pieces for someone to mess with.
Having said that I am just waiting for someone to crack our pcm so that all these goodies won't be wasted with a 6500 rpm rev limiter. Once we have a real reflash for our cars out comes the motor and in go pistons, cams and valve train for a funtastic ride
#59
#60
How in the hell are they going to know you have aftermarket pistions unless one of them seizes and they have to crack the block? They arent and even then I highly doubt the mechanic knows EXACTLY what the stock pistions look like.
#61
He used the last of his energy reserves getting up off the couch and grabbing that box of twinkies he stashed away. Could take Jay 4 months to do his clutch now.
Sorry dude, I had to...
#64
Not necessarily, that's what the magnusson-moss act is for. They must prove with substantial evidence that the part in question is what caused the malfunction.
#65
Yes, the dealership has to prove that what you did affected the part in question, but if you replace the pistons and raise the compression you are putting more strain on the motor, and they will use that to imply a direct result on the portion of the car you are trying to warrenty.
Transmission broke because you added HP, shocks went cause you are making more torque, engine blew because you added more power. Thats what they will tell you.
Bottom line is that you have to pay to play. Hell, even mopar was watching the forums to see who modified thier cars and tried to put them back to stock to get warrenty on motors and such. The guys from MOPAR even took down my VIN number at a meet because I had an aftermarket turbo.
#66
Originally Posted by Tiny@revitup
Because just like in the SRT world, where MOPAR has released pictures of our parts to thier dealerships in a "do not warrenty" update, the manufacturers aren't as un-informed as your think.
Exactly. Above all else, they even have the right to void a warranty due to "abuse". So, if you're worried about warranty, don't even mod the car. The best thing to do is find out what your local dealership will allow.
#67
#68
Originally Posted by Doc
very true...good advice too..
You know what I'm waiting to see? If any cars that have the GM stage kits get voided warranties. It would really be sad, but unfortunately, we are likely to see atleast one case of someone's warranty getting voided on a GM Staged car.
#70
If you read the ECOtec Build book for the 250-400hp engine assembly and you follow that procedure for swapping pistons....
It would be pretty easy if you think about it...
#71
ok, this may sound like a very dumb question, but i'm a car noob so bear with me. what does the compression ratio mean? i asked my bf, but he wasn't entirely sure. thnx.
#73
#74
that's kinda what i was guessing. so in a 9.5:1 engine the air is compressed to 9.5 times is original volume on the compression stroke. and the more air compressed the more powerful of a bang...?
