Intense Stage 4 Dyno Results!
LSX RWD S/C conversion
What has not been mentioned is that you are not actually tuning your car with the Intense Stage anything. The HPTuners software is being used as a generic tune. If you were able to actually have it tuned using HPTuners, on a dyno then quite likely you would be getting results based on your car alone.
Originally Posted by mattyfinch
those numbers are HUGE BAD.....i mean like grose.
i have intense stage 4, and i stock dyno'd 211 whp 187 t and on the SAME DYNO in MORE humidity, i dynoed 281w 264.3 t
According to his sig he has the Intense Stage 5 PCM and 60lbs/hr injectors.. stil u can tell Intense what u have for mods and they adjust it accordingly.. not total accurate but close.. i'm thinkng if he's still on the stock belt without the tensioner and running a 2.70" pulley i'm thinking that the reason he's not making any more power after a certain rpm or just having low numbers that it may be possible that the belt is slipping
Originally Posted by BooSSted
I have a bigger Idler pulley. The belt is not slipping because the boost isn't dropping at all. I was hitting 18psi at redline on the dyno.
ahhh ok... Was just trying all options
I didn't shut it down. I ran it all the way to 7000rpm. The car just stopped making power at 6250
Originally Posted by Jim@Tagracecraft
2006ArrivalBlueSS ...I beg to Differ the Dyno reads correct. We have a new main Ecu unit that was replaced a month ago due to a power surge we had.
Regardless the Car made Great Power and has made the most out of all the Cobalts we have seen.
The only thing i could attribute to the lower tq number is some heat soak.
All in all great Car !!
Originally Posted by Psykostevo
If you did not do the boost bypass mod then you would run ~17lbs of boost to ~6000rpms and then loose to ~12lbs of boost. That could be why power peaked out. If so try it with boost bypass mod and you should gain a lot of higher end power!
Actually it doesn't. The boost bypass is disabled with the Intense ECU. I saw 18psi right to redline
Oh, one more thing... Getting air in and out on a forced induction engine is critical so look at a CAI and a good exhaust and see if that helps. I have the Magnaflow system and I love it! Fit great, Sounds crazy and I definitely noticed a diference in acceleration and throttle response. Sorry for the super long post, just wanted to help
I think my main problem on the dyno was heak soak. I did the pull in 4th gear and it just takes too long to get to redline with our long gears. The next time I go back to the dyno I am going to try and run it in 3rd gear and see what sort of difference that makes. As for the ECU, The Stage 4 and the Stage 5 ECU are the same thing so I am sure I am running a little rich with the 2.7" Pulley. I am going to have to get another dyno done with an A/F reading so I can see exactly what's happening
281 whp and 266 torque is what i look foward to!! I will purchase INTENSE S-4 w/2.6" this week and praying for numbers like that. All I have is an Air box mod and will have a Quick Time Electric Cutout (in the mail!!!). So I am hoping to see some good numbers.
